Old 01-23-2009, 05:21 PM   #1
XYaris
Drives: '09 Yaris LB
TRD Spring Install Labor Costs
This is not something I want to do myself.
Im just curious what people have paid/time it takes to do the install.
I know the back is super quick.
I did a search for this first and found nothing about labor costs.
maybe Rockland Toyota can hook something up if I take a trip up to him?
*just realized this should be in the suspension area...oops
XYaris is offline   Reply With Quote
Old 01-23-2009, 05:46 PM   #2
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
actually...the back are the most difficult ones, the front ones involve a lot of taking stuff off but are a lot easier to work with, I do them and charge 250.00 for all 4.
Don't be threating me with a good time!!!
anubisx99 is offline   Reply With Quote
Old 01-23-2009, 06:05 PM   #3
33OH
Drives: '08 Yaris
I did mine myself and the back springs just fell out once I took out the strut bolts. I thought they were easier.
Also, I would recommend doing this yourself. I'm hardly mechanically inclined at all and I just followed the DYI and installed my Tanabe DF210's in about 2 hours.
Old 01-23-2009, 06:14 PM   #4
at3GG
at3GG's Avatar
Drives: 07 metmet LB
ryank, you use a spring compressor or no?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 01-23-2009, 06:22 PM   #5
33OH
Drives: '08 Yaris
Yes I used spring compressors.
Old 01-23-2009, 06:56 PM   #6
The rears are way easier. We do it for $100, takes 2-3 hours. Two tools are helpful, a spring compressor and an offset 17mm box end wrench so all the cowling doesn't have to come off.
Old 01-23-2009, 07:01 PM   #7
33OH
Drives: '08 Yaris
Yeah I did have to take my windshield wiper cowling off. PITA.
Old 01-23-2009, 08:58 PM   #8
andruboz
boohachimono
Drives: 07 hb
Send a message via AIM to andruboz
I was charged $170 for the front including alignment. I removed the cowl for them and did the back myself.
andruboz is offline   Reply With Quote
Old 01-25-2009, 09:34 PM   #9
XYaris
Anyone near NYC wanna make a few bucks? Id like to at least have someone who has experience and tools by my side.
Old 01-26-2009, 07:32 PM   #10
MUSKOKA800
MUSKOKA800's Avatar
I bought the quality strut spring compressor on sale and did it myself in the driveway.
Word of advise. If you have a rear swaybar already installed remove it first. Otherwise if you follow the TRD directions and do one rear side at a time the axle cannot fall far enough to pull out the OEM spring.
The whole job took me about 4 hours alone, first time with all the necessary hand tools including allen keys, torque wrench, floor jack, stands and an electric impact gun. If I were to do it again I'd estimate 2.5 hours easy. I did have a few delays such as the mentioned swaybar issue plus I assembled the first strut with the spring seated incorrectly which required me to re-compress that spring and rebuild the assembly.
One plus of having the install of TRD parts done at a Toyota dealer is that the parts then fall under your Toyota warranty, for whatever term you have left. Including their extended warranty. This may make it worth the effort of at least getting a quote from your local dealer and then depending on their rate weigh the cost vs. warranty gain.
Should you install the parts anywhere other than at Toyota only the one year TRD warranty applies.
Old 01-26-2009, 09:39 PM   #11
06silveryaris
Drives: 2006 yaris
I did them myself as well and it was very simple especially the rear, the front has a lot of taking apart but it is a all easy. The key is having the right tools for any job. (spring compresors). Take off the wiper motor bracket it is so much easier that way. I would really suck if you strip that allen on top of the shock.
06silveryaris is offline   Reply With Quote
Suspension install: Spring Compressors? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-18-2007 10:59 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
17" Kobe, Spring Tech, TRD FlintS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 09-24-2006 10:39 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 08:32 PM
