Old 01-27-2009, 04:35 PM   #19
Chupacabra
Drives: 2009 Yaris liftback
I just ordered two of the valves. In doing some searching I found coupon code YM4 - It is a 10% discount, which in my case offset the $5 shipping charge.
Sweet Scott. I LOVE the valve. Very cool and the way you actuate it, it's pretty much fool proof from road debris or anything. Very nice piece. It worked well on my first oil change too as I slight over-filled. The car really takes about 3.5 quarts.
derekveliz2,
The filter is VERY EASY to remove with channel lock pliers. Available at any hardware store. If you can't get the filter off with a good size pair of channel locks....you have issues.
Chupacabra is offline   Reply With Quote
Old 01-27-2009, 04:57 PM   #20
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
I recommend using slipjoint pliers to get the filter out i have had the best luck with that.
I also do my oil changes every 4k with full syn.
ka0sx is offline   Reply With Quote
Old 01-27-2009, 05:17 PM   #21
Chupacabra
slip joint and channel lock are the same thing.
Old 01-28-2009, 11:46 PM   #22
ka0sx
ka0sx's Avatar
haha, I didn't even read your post, didn't see page two or your post.
Old 01-29-2009, 04:28 AM   #23
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Why not use the correct tool to get your filter off,
http://www.upscaleauto.com/Oil%20Filter%20Wrench.JPG
or
http://www.classic-car-magazine.co.u...ter_wrench.jpg
Extracting the filter with channel lock pliers can get very messy if you tear into the filter side wall.
Old 01-29-2009, 04:38 AM   #24
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
With Jambo's links... the cap, make sure you get the plastic one and not the metal version for your socket wrench. The metal ones tend to deform after a while and you'll have to buy another.
The size would be "A".
Old 01-29-2009, 08:14 AM   #25
Klink10
Klink10's Avatar
I had been thinking of that valve for the car for a long time...it's on the way now. Thanks for the coupon code....CTScott
Old 01-29-2009, 10:34 AM   #26
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
TWO TIPS::::
TIP # 1 when removing the stock filter (the first oil change) it will be very tight and no oil is on the gasket so that doesn't help things.
TIP # 2 put oil on the new filter gasket this will make removal a breeze
Old 01-29-2009, 10:55 AM   #27
mimelio
Drives: NONE
When I took the factory oil filter off I had to use a pair of Channel Lock pliers (slip joint) that filter was sure on tight and yes they never oiled the gasket.
mimelio is offline   Reply With Quote
Old 01-29-2009, 12:29 PM   #28
IllusionX
Drives: 07 Yaris Sedan Aero
I'm pretty sure the filter HAD some sort of oil on it, because when you buy a new OEM filter, the rubber ring does come with thick grease (looks like silicone grease to me)
Old 01-30-2009, 07:03 PM   #29
Received mine in the mail today (3 days after ordering). I need to do oil changes on both vehicles this weekend, so both will be getting their new valves...
Old 01-30-2009, 08:43 PM   #30
MUSKOKA800
MUSKOKA800's Avatar
the ramp may not empty the oil all the way coz its tilted..
Marcus,
The drain plug is at the rear of the pan so using ramps under the front tires not only gives easier access but helps the oil drain faster.
Old 02-01-2009, 03:39 AM   #31
GeneralDon7
Drives: Yaris Sedan
I am not a small person, and I never have to use ramps or a jack, I use a socket to get my oil filter out, the first time was a b****, I was down at the gf's, and I didnt want to go out and buy another tool, so someone showed me how to use a hammer and a screwdriver as a way to gain leverage, since your not going to be reusing the filter anyway. Worked like a charm and never did any damage. Now i put oil on the gasket and it comes off easy. I use Mobil 1 filter and oil.
GeneralDon7 is offline   Reply With Quote
Old 02-02-2009, 11:36 AM   #32
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ok i just did my oil change and i didnt have to jack it up at all..i also have trd spring as well on my RS... i kinna spilled the oil due to i cant have the oil pan while im takin gthe bolt out.. not enuff space.. oil filter is a little tight i did use oilfilter wrench for it.
by the way i went with amsoil 5w-30.. 2 days of driving and noticed an increase on mileage already.. i had mobil1 synth previously and i notice decrease on mpg on my first tank..and it went all thru out..so it maybe true that mobil1 still have a lot more friction than amsoil... ill start a thread on this...
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Super Amazing Oil Change DIY id3379 DIY / Maintenance / Service 34 11-28-2008 01:20 PM
DIY - oil change kurokoma-kun DIY / Maintenance / Service 7 11-20-2008 12:12 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
