Old 01-30-2009, 12:59 PM   #10
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
Originally Posted by cleong View Post
Try keeping the key held at START. When you stall out, it doesn't seem to want to re-start until you keep the car cranking over.
Our cars automatically crank until the engine starts... try it, just tap the key to the start position and immediately let go -- it'll keep cranking until the engine starts.
I suspect that the OP isn't pushing the clutch all of the way in... there's a switch under the clutch that must be depressed for the engine to crank. It's also possible that this switch is bad, I've had them go out on other cars before.
twowheels is offline   Reply With Quote
big older car vs little newer car xed General Yaris / Vitz Discussion 9 09-16-2007 04:35 AM
Which car to choose? CompanyXPaladin Off-topic / Other Cars / Everything else Discussions 10 09-12-2007 07:53 PM
New Siphon Mag: Yaris vs. xA vs. Versa vs. Fit @ Streets of Willow Ran Kizama General Yaris / Vitz Discussion 9 06-18-2007 12:42 AM
Buying a first car..lol Blenjar Off-topic / Other Cars / Everything else Discussions 11 06-13-2006 11:58 PM
holy sexy clutch birdy General Yaris / Vitz Discussion 8 05-05-2006 08:34 AM
