Old 01-29-2009, 07:40 PM   #19
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Originally Posted by CASTREX View Post
The car will be going the turbo route.... As part of the deal I picked a super rare Trust (Greddy) turbo manifold and the car already has a high capacity fuel pump installed.
The project will likely go slow as the founds are tight... but I will be posting the progress.
The goal. 250rwhp
So what you think?
Very , very good starting point you got there . What I would do to the car is all suspension first . There is such an amazing aftermarket for the ae86 suspension wise. I've seen any and every suspension part to make this car into an killer track car . Now on to your 250 rwhp , not to burst your bubble but its gonna be very expensive to do with that motor . Honestly you need to gank the motor , rebuild it using all upgraded parts to handle boost , turbo , piping , intake , fmic , oil supply/drain for the turbo , exhaust downpipe fabbing , waste gate/ dump (depends of if using internal or exteral Wg?) upgraded injectors , bov , and some kind of fuel controller(minimum apexi afc2) are needed for this project as well as a few random gaskets for the turbo mani to head /turbo to mani, oil gaskets, turbo elbow gaskets , dp gaskets . All these parts add up real quick just what I listed above is at least 5k+ then with more power you'll need to upgrade your clutch/flywheel . Imo , madd suspension modds , don't be scared to buy quality used suspenion parts for the car , and just run the engine in the car As-is with just a underdrive pulley and upgraded intake till it kicks the can , then upgrade .
Old 01-30-2009, 12:59 AM   #20
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I'm probably shooting a little high with the 250 hp goal... but we will see..
I'm well aware of all the implications of going the turbo route... but I'm sure I call pull it for much less than the $5K you mentioned...
For suspension I'm looking into Megan coilovers for around $800
4 links and a couple other bars and good to go...
I will probably go by stages... with a first stage on the stock engine with low boost 6-7psi around 150whp
And going for a 4agze (supercharged)block or at least the pistons and rods for 15-18 psi
The greedy manifold I got comes flanged for a TD05 turbine... so I guess I could use a subaru turbo which can be found fairly cheap...
Supra OE Injectors, ebay universal FMIC and DIY piping kit..
Downpipe and exhaust I'll get them done locally.. not that expensive.
Spec stage 3 clutch with oe flywheel...
And for management I've been looking into the Megasquirt DIY
I guess the good part of working on an old car like this one is the great availability of parts and the possibility of exchange them.
Is definitely a lot of work to be done... but if done patiently it can be pulled on a budget and still with quality parts...
Old 01-30-2009, 02:18 AM   #21
NonStopTuning
Sounds like you've been doing some homework there! Some reading on 86garage perhaps?
MIKE @ NST
www.NonStopTuning.com
Old 01-30-2009, 02:27 AM   #22
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
pssst. its very easy to put a 1jz in as long as you know how to weld a bit.
1jz = 2.5l 280hp with aftermarket dp you will be at 300-310hp so about 250rwhp
ka0sx is offline   Reply With Quote
Old 01-30-2009, 11:02 AM   #23
CASTREX
CASTREX's Avatar
True that!!! But you will completely loose the balance of the car..
Like putting a LS1 on a Miata...
Plus the car doesn't have enough room for the tires that will be required to lunch that beast.
It will be cool tough to see peoples face....
Old 01-30-2009, 07:24 PM   #24
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Awesome Man Keep us posted, ive been interested in the Trueno Hatch also
Seen a couple down here in Puerto Rico, Saw one going for $500 but had no cash damn lol
Arkhangel is offline   Reply With Quote
Old 01-30-2009, 11:30 PM   #25
CASTREX
CASTREX's Avatar
It's so hard to find a clean AE86...!
Look at me... I was looking for a GTS Hatch originally and end up with a SR5 Coupe.
It's so freaking funny to drive this little car... I barely fit inside but I can't get enough of it...
I was doing some donuts and e-brake maneuvers in front of my house tonight... I bet the neighbors are quite happy wit my new toy...
Old 01-31-2009, 01:44 AM   #26
Zefoxe
¦µ¶Œ€♦åËÆ⌐š└╘○Å╝◙þ·▲
Zefoxe's Avatar
Drives: Scion xD
Send a message via AIM to Zefoxe
I miss our Hatchback :(
Coming 2010: Toyota iSt CK edition (CooperKiller) stay tuned
Zefoxe is offline   Reply With Quote
Old 01-31-2009, 02:58 AM   #27
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Nice car. It's really hard to find a nice non-rusty car like that over here. A bunch of my friends all have hachis. Even got a few 4AGZE's. One of the 4AC cars got a SR20 swap after about 3 blown motors, lol.
Old 02-01-2009, 03:09 AM   #28
jeremyshay
jeremyshay's Avatar
Drives: 07 Meteorite Metalic Liftback
Send a message via AIM to jeremyshay
i hate you soo much right now!
awesome find!
You don't get it, do you? This isn't "good cop, bad cop." This is fag and New Yorker. You're in a lot of trouble.
~Kiss Kiss, Bang Bang
jeremyshay is offline   Reply With Quote
Project for a friend wsladaritz In Car Entertainment + Electronics (audio / video / alarm) 5 01-07-2009 09:38 AM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
AE86 owners here? POST PIC'S AE86Yaris Off-topic / Other Cars / Everything else Discussions 6 08-16-2007 03:28 PM
Re-Wiring Project - Any advise before I begin? vodkalush DIY / Maintenance / Service 12 05-13-2007 06:22 AM
