Old 01-31-2009, 05:42 PM   #5
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
If it's the one that covers the corner of the tank, where the exhaust passes by, then it is there to protect the tank from heat. There are three mounting points - One is a bolt, the second is a nut that also holds the floor heat shield, and the third is a plastic pop-clip like the ones that hold the bumpers on.
Yes, that is the one. The bolt/nut that is connecting it to the fuel tank is missing (looks like it's in the middle of the shield).
Do you think the knocking noise I am hearing is the nut rolling around inside the fuel tank?? Yikes.
devinlamothe is offline   Reply With Quote
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 03:26 AM
Fuel Capacity ? ttufrosty DIY / Maintenance / Service 19 08-27-2013 12:14 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
