Old 02-10-2009, 11:26 AM   #13
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
i wonder if this will have the same issue the TC and XB had where the pillars the harness bar was attached to started to cave in after some time
by this, do you mean that over time the chassis of the tc and xb began to flex causing the B pillars to come closer together? If that is the case, this bar should help that, as it would continuously be holding it at the dimensions it is installed in, if your car has already had this "dimension change" that is the reason for the slot in the brackets, to allow for slight differences in chassis measurements
Oh and tamago, it looks like the hatchback is 3/4" wider at the B-pillar, or at least thats what the collision section of the factory repair manual says, page DI-5 and DI-8 measurement J-j is the measure from the top of the B-pillars, I will have to double check on a actual liftback.
turboyaris is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 05:23 AM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 02:34 AM
Yakima Q towers and roof mounts (no bars, locks) for sale $125 shipped pxpaulx Items for Sale by private party 6 04-24-2007 11:54 AM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 05:19 AM
