Old 02-13-2009, 12:51 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by Parmas View Post
Btw is there any Platinum spark plugs for the 1NZFE?
I don't think Platinum is the best choice for boost applications.
You need either the cheaper copper ones or the expensive Iridiums.
Must people use the coppers for the tunning period and once the engine is all set go to the Iridiums for daily usage.
And yes, there are Denso's and NGK's for the 1NZFE in several heat ranges.
Old 02-13-2009, 01:47 PM   #2
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
that engine would look soooooo sick with richard holdeners intake manifold.
Old 02-13-2009, 07:28 PM   #3
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
What do you think about these? http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=380100289012
If all works fine and remain some free cash to spend then a custom intake mainfold will be taken into consideration beyond 15psi boost!
BTW I cannot forget about the gauges, exhaust tips and oil cooler ... here are some pics
Old 02-13-2009, 11:39 PM   #4
CASTREX
CASTREX's Avatar
Yeap, those are the recomended iridiums for the normally aspirated Yaris BKR5EIX.
But for your engine you need to go 1 step colder. Perhaps even 2 steps colder if you are going with high boost (you shoud ask this to your tuner).
On NGK the next step colder would be BKR6EIX
On NGK, the higher the number , the colder the plug. Heat range 6 is one step colder than a heat range 5.
side note: On Denso is the other way around... The Higher the number, the colder the plug.
Those should be easy to find on your local auto parts shop. Just go and ask for Yaris Iridium plugs, and then go for one step colder.
Just stick with either NGK or Denso.
Old 02-14-2009, 05:31 AM   #5
Parmas
Parmas's Avatar
Thanks for the info mate!
Old 02-25-2009, 01:21 PM   #6
Parmas
Parmas's Avatar
Hey man I checked out a thread on scionlife about the intake mainfold made by user castrex (not sure if is the same person in this forum) and it seems interesting. Do you know if it is for international sale and if it fits the first gen yaris?
Old 02-25-2009, 03:27 PM   #7
CASTREX
CASTREX's Avatar
Yeah it was me... but If I were you I would not wait for that manifold.
This is been going on for months and months and months...
The company that was supposed to manufacture the intake, scrapped the project early this year.
And the guy doing the design has not posted a thing for several weeks now.
Old 02-26-2009, 04:49 PM   #8
Parmas
Parmas's Avatar
Ok just a thought, so it has to be custom made aswell although still not considering higher boost than the plastic mani can hold, at least for now!
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 12:43 PM
cali yaris built motor cali yaris Performance Modifications 83 09-04-2009 12:08 AM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 03:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 11:58 AM
