Old 02-14-2009, 10:00 AM   #8
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Yeah. You need to properly describe the problem to get the correct answer. If the ride is rough (which... compared to something like a big Lexus, it is), there really isn't much you can do about it besides fit tires that have softer sidewalls to absorb more road imperfections and make the ride smoother.
If you're feeling too much body sway, like from cross-winds and such, then the rear swaybar will definitely help. But, that's not adding "smoothness", that's adding "stability".
Upgrading to more performance-oriented 15" tires (or even better 14" tires to a lesser degree) will also help with stability.
You might try raising your tire pressures a bit. 35-38 is about right, but some people run 40-45. That will improve steering response and eliminate most of the "give" in the tire. Will definitely make the ride LESS smooth (the tires will transmit every little bump in the road), but somewhat more stable.
Stiffer suspension - same ride height? fuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-13-2009 07:53 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Final Got My 2ND Mod For My Yaris! pp.sweet DIY / Maintenance / Service 10 09-24-2007 02:52 PM
ait resistor mod pigpenracing Performance Modifications 24 08-25-2007 11:14 AM
My Ride.... digital_strings Photo-Video-Media Gallery 13 05-19-2007 09:02 AM
