![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
The Big One upgrade
Here are some pics of my upgraded grounding system. Just used some 0 gauge from KnuKonceptz(Ultraflex) a little 3/4" heat shrink from Home depot and a 0 gauge ring terminal from KnuKonceptz. I also a negative battery terminal from them. Not much of a difference, just a bit smoother throttle response. It should make for better ground for the 3 amplifiers I will be installing.
Amazed at the poor quality of the grounding wire! I think anyone would benefit from a simple 6" add-on ground upgrade probably 4 gauge. |
![]() ![]() Drives: Vitz RS 1.5 Join Date: Feb 2009
I will be doing this too! :) Thanks for the photos!
![]() ![]() ![]() Drives: '07 Yaris S Sedan M5 Join Date: Jul 2007
Another DIY Ground Wire option...
http://www.yarisworld.com/forums/showthread.php?t=2313 And stay grounded... http://www.yarisworld.com/forums/sho...3&postcount=82
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| 17" tires/wheels too big?? | death is my gift | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 04-26-2007 10:39 PM |
| big brake kit | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-13-2007 01:44 PM |
| Big Brake kits for Yaris 5 door | mojoyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 03-23-2007 12:30 AM |
| So how do you like the BIG SMILE on the 07 Sedan???? | Ziv | General Yaris / Vitz Discussion | 3 | 02-03-2006 11:12 AM |
