Old 02-15-2009, 11:25 AM   #19
Dorkinheimer
Dorkinheimer's Avatar
Drives: Yaris 2007 *manual*
Originally Posted by enobmort42 View Post
it's a great city car, but imo, an even better highway car. ya can't beat going from NYC to orlando on $75 worth of gas. after a state or two, you don't even hear the engine anymore.
...this compared to my last car: '96 concorde that got MAYBE 15 mpg highway! =P
At a certain speed you don't hear the engine as much because of harmonics. You'll hear the engine alot at 3000 rpm and hear it less at 3500 for example, but it's still spinning too fast.
As for being easy on gas, it is, but that's not what I'm talking about here. IM talking about the RPM at highway speeds, which is too high for comfort, and for the engine's life.
I tried my friends Echo, and his motor spins 400 RPM slower than my Yaris. He has the automatic transmission and the 2005 Echo was geared to spin slower and it was a charm driving it at highway speeds.
Dorkinheimer is offline
Old 02-15-2009, 11:45 AM   #20
roxy1
Drives: 2014 yaris 5 speed
while the higher rpm's on the highway may be irritating, the notion that it is too much wear and tear on the engine is silly. i am certain that many yaris owners with the 5 speed will pile up 200k highway miles on this engine with no ill effects as long as they maintain it properly. 3200 rpms for long periods of time is not going to ruin this engine.
roxy1 is offline
Old 02-15-2009, 12:36 PM   #21
churp
Clean and (dis)Functional
churp's Avatar
It's great for both....but if you really feel it's aimed more for one or the other, change your tire diameter. Changing diameter will change the compromise to favor one at the expense of the other.
____________
Old School Cobble Jockey
churp is offline
Old 02-15-2009, 12:38 PM   #22
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Here's your answer:
http://www.yarisworld.com/forums/showthread.php?t=13471
Altitude is offline
Old 02-15-2009, 12:40 PM   #23
ChinoCharles
Drives: LB
^^ I was just about to post that. No reason to wonder how much "punishment" the engine takes @ highway speed. The answer is not much.
ChinoCharles is offline
Old 02-15-2009, 12:49 PM   #24
frownonfun
frownonfun's Avatar
wow this thread makes like no sense.
frownonfun is offline
Old 02-15-2009, 12:52 PM   #25
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Well I guess it's safe to say this thread is now dead
SilverBack is offline
Old 02-15-2009, 12:53 PM   #26
33OH
Drives: '08 Yaris
I do 95% highway driving and don't see anything wrong with it. My motorcycle revs at about 7,500-8,000 RPMs on the highway and that's with 6 gears.
What, do you want to have to drop into 2nd gear in order to accelerate a few MPH on the highway?
33OH is offline
Old 02-15-2009, 12:59 PM   #27
JBIZZ
Drives: 2007 Liftback white
It is Ideally a city driving car, but has no problems cruising at 80 on the highway, & will last at least 2X longer than a bigger U.S. built car under harsh driving conditions (i.e. flooring it at every light).
JBIZZ is offline
Old 02-15-2009, 01:09 PM   #28
SilverBack
Joey
SilverBack's Avatar
True. As long as it stays around 3K RPM, there should be no overheating and excessive wear-n-tear on the engine or tranny. Now if you were to do something like push it to 80MPH in 4th (or maybe even 3rd if the limiter doesn't get you), you're asking for trouble way down the road
Old 02-15-2009, 01:39 PM   #29
SailDesign
Drives: .
I dunno, krayzee - 80 in 4th is only 4100 rpm, and in 3rd it is still way below redline at 5500 rpm. Not recommended for long, but you shouldn't do any damage to the engine just getting there temporarily.
SailDesign is offline
Old 02-15-2009, 02:01 PM   #30
I read this thread and I want my four minutes back.
the OP has a fixed point of view on this (as we all do, I'm sure). If there were a hundred posts saying the car is great for highway and long distance driving, he would still have the same view, which of course he's entitled to. -- so, are we discussing something?
cali yaris is offline
Old 02-15-2009, 02:09 PM   #31
SailDesign
Drives: .
Yes, or No. It is either a viciuos circle or a circle jerk, and no way to tell which.
And No, you can't have your four minutes back.
Old 02-15-2009, 02:10 PM   #32
SilverBack
Joey
SilverBack's Avatar
Let's all just agree to disagree, ..whatever the hell that means...
Old 02-15-2009, 02:25 PM   #33
SailDesign
Drives: .
OK.
Old 02-15-2009, 02:34 PM   #34
Dorkinheimer
If there could be a 6th speed to the manual Yaris, wouldn't you guys go for it, or would you say, nah, we prefer a 5 speed that revs 3500 rpm at 130 kmh.
I would say, heck, bring it on.
And yes it would be a good idea to put bigger wheels on the car to lose 200 rpm or so on the highway.
Maybe if I had 15 inch tires instead of my 14, that there would have been a 100 rpm difference.
Old 02-15-2009, 02:39 PM   #35
Dorkinheimer
Oh it does for someone thinking of buying a manual Yaris and not used to having rpm's up in the mid 3000's.
They will probably go for the automatic which spins 200 rpm slower ;)
I would have done that if I would have known back then.
Old 02-15-2009, 02:44 PM   #36
Kal-El
Kal-El's Avatar
The OP is suggesting that 68 mph (110 kph) is the comfort limit for the manual?
That's ridiculous.
I have a MT and it only rev's at about 3300 at 80 mph (129 kph). About 3000 at 68 mph.
That's pretty relaxed. The member with 305,000 miles posted a top speed run of 115mph with no problem.
Point is, this is a great highway car. Why do people consider small cars only city cars??? You can drive the Yaris 85 mph all day long.
I'm also boggled at why the MT is said to rev higher than the auto? The MT gets even better highway mileage than the auto. My MT is very calm and smooth on the highway.
BTW, city driving is more wear and tear on the engine than 80 mph highway cruising.
Kal-El is offline
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 02:23 PM
