Old 02-16-2009, 05:03 PM   #1
Havoc
Zee Bold Novice
Drives: 2009 Yaris 3Dr
GTSPEC Bars and Braces
I just installed the front and rear tower strut bars today. There is definitely a noticeable, slight tightening on handling all around in my opinion. It holds a line a little different on uneven spots, feeling more solid actually. It seems a bit more responsive cornering. I noticed that coming out of a steep turn. It seemed to come out of the roll effect a bit faster. (no lowering or coilovers here yet)
If anyone has advice on how to install the 4 pt. lower front brace or rear sway bar, I would greatly appreciate it. I'm just uncertain how to safely go about taking off the frame bolts for the 4pt brace, as well as if I can just jack up the back and undo the bolts to install the sway bar.
Note on Front Bar: This is attached with 2 bolts only, the inside bolts. I don't know if that's how it was intended or not, but the other 2 holes do not line up. (2009 3dr)
Havoc is offline   Reply With Quote
Hit financial hardship, so some mods must go-CF wing, front & rear strut bars, braces Astroman Items for Sale by private party 69 05-08-2009 09:28 AM
