Old 02-25-2009, 01:05 PM   #1
i found in a stock yaris the power just isnt there to redline...maybe 6000rpm is more accurate....maf might need cleaning too at this point....but i figure ill wait till spring....
i find with a proper intake the power runs to redline....
thebarber is offline
Old 02-26-2009, 05:28 AM   #2
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
K&N Drop in Filter FTW!
id3379 is offline
Old 02-26-2009, 02:26 PM   #3
Yaribhini
Drives: Yaris
Interesting that almost everybody missed the point that I tried to make and that is not that the K&N flows less than paper media, it is that it does so at the cost of filtration. A K&N let's more in which constitutes a dirtier motor and throttle body. I'd love to hear the arguments for needing more airflow for this 100hp air pump. Please don't kid yourself into thinking that the K&N is giving you better results. The only think that it's doing is making your motor and throttle dirtier.
Chino,
I assume you have your Yaris on the track often? That K&N filter must have you blowing by all the Porsche's and BMW's!?
C'mon guys, stock paper media is where it's at with this Yaris. That's a "no brainer."
Yaribhini is offline
Old 02-26-2009, 04:27 PM   #4
1stToyota
1stToyota's Avatar
Chino,
Is that what the stock Denso filter is made out of? I thought it was a recycled egg carton.
It was too wierd looking for me so I went with the Beck/Arnley paper filter and got impressed, real quick!
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
1stToyota is offline
Old 02-26-2009, 08:22 PM   #5
jaserhunter
jaserhunter's Avatar
Drives: 2008 yaris LB
if K&N is sooo bad for your car then why do so many people still buy them? and are you guys really fighting over this.
come on..... really cause everyone knows that
K&N is the best lol
"Igitur qui desiderat pacem, praeparet bellum."
jaserhunter is offline
Old 02-26-2009, 10:13 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You are actually wrong... Paper filters let very fine dust right through that coats the inside of the intake tube and can easily be seen when replacing the filter. An oiled media on the other hand catches all that fine dust and traps it. The inside of the intake tube on my Tacoma looked like it was removed from a brand new truck, and that was after 50,000 miles without cleaning the K&N. Trust me, they work, even in harsh conditions...
As for the MAF, I have personally over oiled a K&N filter and caused a CEL. But cleaning the MAF is SIMPLE (using CRC MAF cleaner, don't EVER touch the element with a q-tip) and disconnecting the battery resets the light. No harm done.
Compared to a stock paper filter, K&N's are better in every way...
PetersRedYaris is offline
Old 02-27-2009, 08:47 AM   #7
1stToyota
1stToyota's Avatar
It's an approved cleaning method on Identifix, unless someone isn't born with dexterity and nerve endings, and is real sloppy.
Paper doesn't invite gunk buildup on the MAF quite as well, causing a 10-20hp loss at the wheels instead of about 1hp gain at the wheels, if you're lucky.
2008 Scion xD
Old 02-26-2009, 08:26 PM   #8
ChinoCharles
Drives: LB
Chino,
No, but my argument is that if they work on 600+ HP drag cars, I think they're good enough for my econobox.
Hey, don't listen. Go spend 20 bucks on a paper filter once every 6 months or a year. I'll still have my K&N in 10.
If you say K&N filters let more dirt in, you're just flat out wrong. You're arguing an invalid point. The world is flat, too, right? Come on now. It is an oiled filter. It operates on different principles, but the end result is simple.
And another thing... () every K&N filter you'll ever buy is going to increase the surface area of the filter element over stock. HELLO? Should I keep going?
ChinoCharles is offline
Old 02-27-2009, 08:53 AM   #9
1stToyota
1stToyota's Avatar
I've never ran codes on a 600+ HP drag car
Sounds like you pulled the trigger on a K&N filter since the 24th!
2008 Scion xD
Old 02-26-2009, 08:30 PM   #10
ChinoCharles
Drives: LB
http://www.knfilters.com/air_filter_testing.htm
^^ The shut up button.
AND I QUOTE
We are aware of the “urban myth” (K&N News Story) created by a few dealerships that a vehicle's MAF sensor can be contaminated by K&N filter oil. No evidence has ever been provided to support this “myth” and three years of diagnostic testing by K&N has shown that not only is this allegation not real, it is not even possible. In our opinion, it is an excuse for a dealership and/or the vehicle manufacturer to avoid a legitimate warranty repair. In the last 4 years, we have sold over 10,000,000 lifetime air filters and received only a few hundred calls from consumers who are having dealership or service provider challenges. We believe that Dealership's or service provider's real incentive may be to discourage the use of reusable products so they can sell disposable products over and over. In order to provide consumers with added comfort that they will not be placed in a bad position by an improper warranty denial, we offer our Consumer Protection Pledge.
Pop quiz: What element of the Yaris's MAF could POSSIBLY get dirty enough to cause issues?
Old 02-27-2009, 07:20 AM   #11
ddongbap
AND I QUOTE
Not that I'm trying to disprove this or anything, then what causes brand new MAFs to fail?
ddongbap is offline
Old 02-27-2009, 09:11 AM   #12
ChinoCharles
Drives: LB
Poor design. MAF circuit boards are sealed w/ silicon, and they are connected directly to the underlying hardware. Engine heat and general wear and tear can cause the plastics of a MAF sensor to degrade and allow some of that silicon to coat the thermistors and other good bits. This is usually the cause of "dirty" sensors... it actually comes from the sensor itself.
Old 02-27-2009, 09:54 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
they also do not react very well to voltage destabilization. lots of improper wiring or a loud sound system will kill a MAF pretty quickly. i saw at least 3 MAF's replaced in a few months while at toyota, all on cars with ghetto-rigged wiring
Tamago is offline
Old 02-27-2009, 08:41 AM   #14
1stToyota
1stToyota's Avatar
[URL]
You've never looked at one? It's not a hollow tube. Noticed the wire harness that plugs into it?
2008 Scion xD
Old 02-27-2009, 03:47 AM   #15
ddongbap
Since Toyota would have filters that'll damage their engines in the long run. Or maybe fine dust DOESN'T MATTER?
ddongbap is offline
Old 02-27-2009, 08:43 AM   #16
MUSKOKA800
MUSKOKA800's Avatar
I've had great success with K&N's over the years with no MAF issues. Here's my process;
Remove K&N drop-in
Re-install original OEM filter (which was nearly new when initially removed)
Remove any litter (bugs etc) from the dirty side with a soft brush.
Using K&N cleaner from kit, thoughtly soak and back-flush the K&N filter with warm tap water.
Shake off excess water and air dry overnight.
Next day (when 100% dry), spray both sides liberally with K&N filter oil ensuring that all pleats are moistened.
Lay filter on paper towelling for a couple hours to drain any surplus oil.
Wipe excess oil from filter frame and re-install in stock airbox.
The K&N service kit suggests cleaning be done at 50,000 to 100,000 mile intervals (for on-road use).
I do so annually which is approximately 25,000 kilometers (~15,500 miles)
I recently cleaned the filter after 27,000 kl. in my Yaris Sedan. It was much cleaner that past K&N's I've used which were cone types on K&N intake systems (Turbo-Talon, 5.0 Mustang). Could be that 1.5 hp doesn't draw the same volume of air as 200+ hp plus the Yaris filter has been protected inside the airbox with dirt only being drawn in from the bottom, whereas the cone filter are exposed to all dirt flying about the engine compartment, not just that pulled up to it by engine vacuum.
MUSKOKA800 is offline
Old 02-27-2009, 09:04 AM   #17
ChinoCharles
Drives: LB
A: The mirror!
Yarii have a Karman Vortex-style MAF. It works via a mirror located in the stalk of the sensor. Air is redirected up the stalk and against a tiny little mirror, and the oscillations of that mirror are measured via a photoreceiver that receives LED light that is reflected off the mirror.
SO, you guys are telling me that oil from a filter is going to make it all the way up the stalk of the MAF, contaminate it, and then the filter is going to let in enough dirt (which is also magically going to take a trip up the stalk of the sensor) and ruin it, too?
No, it won't. That is why Toyota uses these MAF's and have for decades. They are reliable. That is to say nothing of the fact that properly installed oiled filters do nothing to air flow sensors in the first place.
You guys are arguing urban legend. It comes up here about once a year, and it gets shot down every single time.
Old 02-27-2009, 09:50 AM   #18
1stToyota
1stToyota's Avatar
A: The mirror!
Thanks. I'll look for one of those at the next StarTrek convention.
I just pulled mine out, it's not as fangled as you make it sound. Look at it. Airflow is directed straight up into the sensor, across the 2 wires that MEASURE the AIRFLOW, passes on thru the sensor and down into the main airflow to the throttle body.
And the main thing that needs to be remembered is that it's not downstream a foot or two, it sits directly above the filter, mounted right on the airbox.
2008 Scion xD
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Cold Air intake with k&n filter _S7V7N_ Performance Modifications 23 12-19-2008 02:36 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
K&N 57i filter for TS 1.8 jim TS Performance Modifications 5 06-24-2007 05:00 PM
