:insert beating the dead horse .gif here:
Its the simplest air flow meter that I know of.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Keyword: air flow ...not a lazer light show held at the hall of mirrors.
so then since you're the expert, explain how the sensor measures air flow
The heated wires measure the air flow entering the motor, PCM measures their frequency. Mirrors SEEING invisible air is a new one on me.
#6 | |
you're wrong
Keep trying to take the focus off the fact that you vehemently argued the world was flat for most of this thread.
![]() With that, I'm out. -drops mic- |
All you had to do is actually LOOK at the MAF meter to see how well the air flow is directed straight across the wires that measure the air flow.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
They don't send you pre-oiled filters? When I bought my K&N it came dry, with a bottle of oil with it.
WRONG, try again.
Tell that to the Yaris owner here that recently asked what was wrong with his Yaris because it's down on power. Most posters jumped in and guess dirty meter. Guess what? Poster stated that he cleaned MAF and now everything is back as should be.
I wonder what he cleaned? Mirrors and lazer beams? No. Dirty wires. :) |
Wires don't measure flow on the Yaris, they measure air temperature.
OK, seriously, I'm done. LOL no point in arguing with someone who knows all the wrong answers. |
#13 | |
I need to hear more about those jiggling mirrors that are no where to be found, that send lazer beams to photo receivers. |
#14 |
and you let this fuckery continue but lock up a poll that really was just a little joke..
mod power!!
#15 |
#16 | |
i left it up to the voter which they'd choose! and clearly it was a joke.. what, did Garm complain? he's not even awake yet
#17 |
Drives: Yaris Join Date: Jan 2009
Ignorance is bliss I guess. I mean, why not believe everything that you read? Just in general, here is one example of many done by Jim Conforti testing both filtration and flow. But as a matter of conversation prior to the Conforti clip let my just say that
stock is good. K&N will flow a BIT more when freshly cleaned up but will also clog quickly, reducing flow. Cotton doesn't filter as well as paper filter media and allows silicium in the engine's oil. There are multiple tests and studies that have shown this and it plainly points to how much BS is rampant in the world of aftermarket performance parts, and how inflated the claims given can be. Think for a moment the claims you read about HP gains from this or that modification and it's also a reminder of how we "enthusiasts" have a tendency to assume ANYTHING non-stock is better performance wise than whatever the OEM manufacterer provided. Clearly that is not always true. As mentioned there a lot of independant tests that have been done but here is one from BMW tuner Jim Conforti. Jim Conforti (AKA the Land Shark) did some testing: This was a scientific test, not one done by filter manufacturer X to show that their filters are better than manufacturer Y. The test results are pretty irrefutable as the test lab tests and designs filters where "screw ups" are absolutely NOT allowable. A scientific test was done on TEST filters where air was loaded with ACCTD (some standardized "test dust" called AC Coarse Test Dust) and sucked through the TEST filter then through an analysis membrane. From the Quantity of dust injected and the amount that gets through the TEST filter and is then captured on the analysis membrane we can calculate the efficiency of the TEST filter in Question. BMW Stock Filter, Eff. Area of Media: 8.4 sq ft. K&N Replacement, Eff. Area of Media: 1.6 sq ft. The filters are the SAME size. They both fit in the STOCK BMW M3 airbox. The difference is that the STOCK filter has 65 pleats 1.5" deep and the K&N only 29 pleats each 0.75" deep. Now, remember this ratio: " 5.25:1". It's the ratio of the AREA of STOCK to K&N. It's very important and will come into play later. The STOCK filter efficiency started at 93.4% at 0 loading and increased to 99.2% efficiency as the loading increased to a max tested of 38.8 gm/sq ft of dust. The K&N filter efficiency started at 85.2% at 0 loading and increased to 98.1% at the max tested loading of 41.38 gm/sq ft. Now, I hear you. "Jim, that's only a FEW PERCENT". But is it? Let's look. If we had 100 grams of dust on a new BMW filter we would let through a total of 6.6 grams of dust in. If we used the new K&N filter we get 14.8 grams of dust. That's 224% (TWO HUNDRED TWENTY FOUR PERCENT!!) more dust ingested initially, stock vs. "free flow" and this ratio is pretty much held. Somewhere between 200-300% more dirt gets "ingested" anywhere across loading equivalence. The more INTERESTING thing is when you look at what happens to the DP or Differential Pressure at a constant airflow as you dirty both filters equally with time. The test used a rate of 75gr of dust per 20 min. Here's where the AREA difference comes MAJORLY into play. See, even though the BMW filter flows a bit less at the SAME loading, it also LOADS UP 5.25 times SLOWER due to it's LARGER effective area. So what happens is that the K&N initially flows better, but as the dirt continues coming in, the K&N eventually flows WORSE while still letting MORE dirt in. Now, does any of this additional dirt cause problems? I dunno. I suppose we could have a few people do some independent oil analyses on different motors using both K&Ns and Stock filters. Get enough of them, and you'd have a good statistical basis. For me though, it's simple: More DIRT = BAD. The additional short-term airflow might makes sense on a track car. IMHO, it doesn't for the street. -- Jim Conforti One of many examples. |
#18 |
No, Garm didn't complain. Nobody did, I was just using my better judgement. Someone would have.
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 105 | 06-20-2019 12:59 PM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| Cold Air intake with k&n filter | _S7V7N_ | Performance Modifications | 23 | 12-19-2008 02:36 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| K&N 57i filter for TS 1.8 | jim TS | Performance Modifications | 5 | 06-24-2007 05:00 PM |
