essentially your outboard clearance is 9.35MM less than is suggested by the experts on yw however, your inboard clearance is only 3.35mm less.
on a 205/40/17 you should be just fine, as the 40series tire is somewhat smaller than stock (overall height)
nice looking wheel by the way :)
oh and, you should spring for some camber bolts, to help with any inboard rubbing you may experience
Originally Posted by xnamerxx
 you nailed it sir.
