AKA Samurai Racer
acceleration vs wheel size and weight
hi Guys
i have a question i need help on please I have a set of 17inch mach10 tenzo R wheels, they weigh about 8.7kg's. most 15inch lightweight wheels are about the 6.5 kg mark , my question: will changing to the 15's make a BIG difference , i know it will make a small diff , but im so use to the bigger wheels , and they look so hot , its a hard choice. any ideas and comments welcome. PS , im going to turbo the car next year |
i think itll make a big difference.
crandall has 17" tenzo R's and i have 14" steelies w/ 185 tires....i notice a HUGE difference in acceleration ive also put crandalls 15" RS oem alloys w/ tires on my car and didnt notice as much of a change in acceleration as w/ his car w/ 17's
Carless in Chicago
decreasing your rotational mass is more significant than removing the same amount of weight from a stationary position...so yeah, whether or not you will notice a sizable difference, there will be one.
this is the main reason the lightweight pulleys from NST increase acceleration so well, less rotational mass.
Wanted: Forced Induction Some say that he is the secret love child of Ferrari and Porsche, and others say that he would lap James May twice in a 1/4 mile drag race. All we know is that he is called The Stig. |
What?
Too lazy to do the kg>lb conversion, but in my experience, on a lightweight car like the Yaris, you'll definitely feel anything more than 3 pounds. Less than that will still make a difference, you just won't notice it as much.
Lighter wheels affect more than acceleration, you can really feel the difference in inertia in the effort that it takes to make a normal stop. |
AKA Samurai Racer
wow , thanks for all the info guys , i recon i should get tires for the 15inch lightweights i have and give it a good test.thanks for the info , GREATLY appreciated !!!
#6 | |
youll feel it.
What?
That's an understatement. 14 pounds to 20 pounds is HUGE.
You guys aren't taking into consideration the weight of the rubber. Even though the 15s are lighter, you'll be rocking more rubber weight.
What?
That's a nice idea, but if you look into it, you'll find that it doesn't hold up.
Your average "lightweight" 15" wheel trips the scales at around 12 pounds. Your average "lightweight" 17" wheel is (and I'm being generous) 16 pounds. The weight of the tires is usually about the same. Though for performance tires, because the heavily reinforced bead area of the larger diameter tire is larger, larger wheel's tire will be heavier than the smaller wheel's tire, even though it has less sidewall. Less rubber, more steel. An when you're talking Yaris tires, the car doesn't need more than 195 treadwidth, but you can't get that in a 17... so you're adding width with the 17, which adds more weight. Have a peek here and tell me which tire size is lighter, the 15" or the 17": http://www.tirerack.com/tires/Spec.j...irePageLocQty= It's always better to go with the smaller diameter wheel if your aim is to save weight. Even 14" wheels would be good if the tire selection wasn't so poor these days. 195/60-14 (typical 18 pounds) on an 11-pound wheel = about 29 pounds. 195/55-15 (typical 19 pounds) on a 12-pound wheel = about 31 pounds. 195/50-16 (typical 19 pounds) on a 14-pound wheel = about 33 pounds. 205/45-17 (typical 20 pounds) on a 16-pound wheel = about 36 pounds. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
They've pretty much already said it, but last week I switched from 15's to 17's, and I've noticed minor acceleration and MPG decreases.
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
i run a 205/40r17 and specifically chose that tire size to keep the speedometer correct... well as correct as it can be with a different size... ran the math and it came out to be 0.67 MPH faster at 30 MPH on the speedo
What?
Nice. But that's not at all what we're talking about.
#13 | |
depending on which tire you buy either 15'' or 17'' there can be 6lbs or more difference.
ekodrvr
if tire diameter is off, it WILL mess up the gas mileage more than the larger wheel size alone. it will also weigh more to have the 45 series vs. the 40 series.
i will admit that i did take a hit on gas mileage switching to 17's, but in the long run, you need to compare the savings in fuel to what style you like. if you really prefer the look and slightly stiffer handling characteristics of the larger wheels and wider tires, then the difference then becomes an academic argument. my advice, do exactly what you like with your car. don't even worry about what others think, because opinions are like a**h*l*s, everybody has one. |
#16 | |
ekodrvr
was not saying that numbers were lying... what i was saying was that aucorium is well within his rights to make his own choices... and he had specifically said in his first post that he likes the look of the larger wheels.
#18 | |
He came here asking questions for answers. We're giving it to him. Good thing this question is easily answered cause numbers are numbers. But, I kind of think you don't know what you're talking about. |
| My Wheel and Tire ideas | why? | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 25 | 01-26-2009 10:30 AM |
| getting bigger rims = odometer/speedometer changes? | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 11-27-2008 01:43 PM |
| 15" Konig Heliums+tire weight info | CASTREX | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 52 | 02-26-2007 09:38 PM |
