Old 07-25-2006, 06:46 PM   #19
bulldogs2k
bulldogs2k's Avatar
Drives: '00 s2000, 2007 yaris hatch
[QUOTE=ChinoCharles]What did the dealership give you on a trade in for your BALLS?!
Hah, just kidding... I think.
Its her car, plus i have my own toys she cant touch.
bulldogs2k is offline   Reply With Quote
Old 07-25-2006, 10:08 PM   #20
ChinoCharles
Drives: LB
Yeah I see that S2000 sitting in your garage. Lucky bastard.
Old 07-25-2006, 11:35 PM   #21
bulldogs2k
bulldogs2k's Avatar
sitting is all its doing...Since we got the yaris, i've been driving it around like a mad man.
Old 07-26-2006, 01:44 AM   #22
ChinoCharles
Drives: LB
Good... an S2000 is a little much for a daily driver. Yaris... now that fits the bill. What all do you have done to that S2000? Post some pictures if you're feeling saucy... I love those cars.
Old 07-26-2006, 09:44 AM   #23
rstb88
rstb88's Avatar
Drives: Silver Hatchback
this may be the wrong crowd to ask but, are the auto transmissions in the Yari adaptive or are they just straight up shift how I want to don't give a damn about your driving curve
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 07-26-2006, 07:46 PM   #24
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
I asked my dealer that too and he told me that they were the type that doesn't give a damn...
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-29-2006, 06:49 PM   #25
rstb88
rstb88's Avatar
damn. even my moms Taurus has an adaptive tranny
Old 02-26-2009, 11:52 PM   #26
bvd
Drives: yaris
i would like to know does yaris display the current gear selection (either in automatic or manual transmission) on its display unit?
bvd is offline   Reply With Quote
Old 02-27-2009, 01:38 AM   #27
tomato
tomato's Avatar
Not on the manual LB. It's not really needed, IMO.
No tach either. Now that would be kind of nice to have, just for fun.
Old 02-27-2009, 07:39 AM   #28
MUSKOKA800
MUSKOKA800's Avatar
Originally Posted by TRD_Yaris View Post
-=DIRECT FROM OWNER's MANUAL=-
This is the best mix between fuel economy and performance..so shifting a bit earlier than these speeds should net you a bit better gas mileage, but less performance... The best thing is to get into higher gears as quickly as possilbe..anytime i'm crusing at more than 40 mph, i (personally) ride in 5th gear..
Low Altitude
gear mph
1 to 2 or 2 to 1 15 mph
2 to 3 or 3 to 2 25mph
3 to 4 or 4 to 3 40 mph
4 to 5 or 5 to 4 (45/40 mph) <--dunno what this means..two values for
manual trans...manual could have a typo..)
As far as keeping the car from jerking back or forward when letting out the clutch...it will take you some time to get use to the clutch and rev-matching (re-engaging clutch with the RPMs exactly where you need them for the speed you're going..though this is REALLY hard to learn without a tachometer which allows you to physically SEE the RPMs and if they jump UP or DOWN when you let out on clutch)
Anyway, good luck with the yaris
WOW!
I can't imagine ever going into 5th at under 50 mph let alone 40-45. I usually find myself down shifting into 4th whenever my speed drops below 100 kph (62 mph). I can't stand lugging the engine. And it has no guts below 3000 rpm. I prefer to be in the powerband for safety and fun. Obviously I'm no hypermiler. I commute 100 kl per day and prefer to enjoy the drive.
Old 02-27-2009, 07:43 AM   #29
ddongbap
My car is one of those oldschool cars with only 3 gears.
First gear, 30mph. (Or whatever the max is)
Second gear, 63~mph. (Or whatever the max is)
Fifth gear, 70~mph.
Btw, rev matching isn't hard. Don't let people fool you. People try to match revs by holding the accl. Just blip the throttle.
Old 02-27-2009, 07:48 AM   #30
TANATAUg
ToughAsNailsAnTwiceAsUgly
Drives: 2008 redredred Hatch
Okay, stupid question: does anyone else here experience throttle hang on low-rev shifts? Mine will shut right down if I wind 'er up; but shifts @2k have to be made verrrry deliberately.
Round here, if it aint a truck, it's a target.
TANATAUg is offline   Reply With Quote
Old 02-27-2009, 07:52 AM   #31
ddongbap
Its actually based on how fast you release the clutch after you let go of the throttle. The less time there is between you letting off the gas, and hitting the clutch, the longer it'll hang.
Some people claim its because its Toyota's way of helping with emissions, by letting fuel burn during the rev hang.
I sorta believe its because it'll allow for smoother shifting.
Old 02-27-2009, 08:22 AM   #32
MadMax
MadMax's Avatar
In the US the automatic displays what gear the transmission is in (e.g. P, R, N, D, 2, 1) on the instrument cluster...
Cheers! M2
Old 02-27-2009, 08:53 PM   #33
bvd
Drives: yaris
^ what if it does not display on the instrument cluster, should i ask the dealer, or does anyone in here know how to enable/disable the display for current gear transmission (in auto)
Old 03-01-2009, 06:46 PM   #34
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
I remember a thread like this before the hack.
Unless your building a race car, you don't need a tach. Just listen to the engine and keep an eye on the road.
As far as shift points go, the easiest way to remember is to shift at every 10MPH (it's also what's been giving me good gas mileage). Example:
1st: 0-10
2nd: 10-20
3rd: 20-30
4th: 30-40
5th: 40+
That's it
Old 03-01-2009, 06:58 PM   #35
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
On the automatic, the dash display shows where you put the lever. It does not show what gear the transmission is currently in.
Shifting RPM GabL DIY / Maintenance / Service 10 08-06-2006 05:40 AM
Auto Shifting knob ? Boo General Yaris / Vitz Discussion 8 07-24-2006 07:21 PM
down shifting and not coasting wushumasterku General Yaris / Vitz Discussion 33 06-13-2006 05:18 AM
