#37 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
hey blazingbluevitz think i can drop my car off after the kit install and have them take a look at it?
"It hurts more when its wet" |
#38 |
SIPNDEW
i use royal purple and have had no issues at all. it shifts better to me.
#39 | |
im guessing they'll say your ssk and short shifter is causing problem. but its worth a shot.....
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#40 |
Did you get the prob fixed
#41 |
i dont have my car back yet... still in the body shop...
#42 |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
I had the third gear grind. The car had 100,000km on it and I never changed the gear/tranny oil. I got Toyota to flush it and was extremely worried after the flushed since the clutch was slipping when I got it back. But after a several days, the slipping went away along with the third gear grind.
I'd listen to tango and either use redline, or in my case, I'd play it safe and use the Toyota stuff. |
#43 |
I have a 3rd gear grind as well. I feel it at higher RPMs both when upshifting from 2nd and downshifting from 4th. I'm getting it looked at on Tuesday. The mechanic actually drove my car and felt the grind, and he says it's not the clutch, but that it could be somewhere along the transaxle. I also have a new ACT Stage 1 clutch in there, so I agree that it's unlikely to be a clutch problem.
I really hope that the warranty covers it though. They've started to ask questions about my aftermarket parts. ![]() They also changed the tranny oil to OEM about a month ago. Would it make any difference if I switched back to MT90 this early to see if that fixes the grind?
#44 |
I get that grind occasionally, however it is only when I shift very hard at high revs from 2nd to third, I have 56k mi. with the engine bay ssk
#45 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
Just dropped my car off at the shop today in the morning. I'll should know by this afternoon what's going on with my tranny
#46 |
#47 | |
Well i wait for them to give me call back... if they find nothing wrong, then it looks like i'll be ordering a case of redline
#48 | |
Even with all the mods i have on. I/H/E and pulley. As long as wat you added on does not directly or indirectly affect the troubled part then you are good. If they deny to fix for free ask them how exactly your mods have contributed to the fail of your trans... you will quickly see how much they can bs and then call them on it. Let them kno you are not stupid and you kno your stuff also.
#49 |
When i dropped it off he asked if i had the gear oil changed. i told him that i did it myself a few months ago. He then said well if we find anything wrong with it by default we will let you know. I'm pretty sure they will try and dump this on me. Of course I'm going to raise hell if they do
#50 |
Ok just got a call back from the dealership... they did here the grind in third gear. They said they wanted to keep the car until tomorrow bc the shop foreman wasn't there. But he said they would give me call tomorrow to let me know what was going with it.
#51 |
ok cool sounds good
#52 | |
toyota
#53 |
I couldn't lie about it... well i could but, they have the transmission drain plug marked with ink. So they know when the drain bolts been removed. I have receipts... put the correct viscosity in there.
#54 |
toyota
you got the receipt then they cant decline ur coverage.. ur good to go.
| Yaris 2007- How to Restart Multimode gear? | ronen | DIY / Maintenance / Service | 1 | 02-21-2009 05:09 PM |
| Auto 'extra' gear? | drecian | General Yaris / Vitz Discussion | 2 | 08-25-2007 08:01 AM |
| High RPM's in 3rd. Need some opinions | falkor_99 | General Yaris / Vitz Discussion | 3 | 05-16-2007 08:23 PM |
| 2nd to 3rd gear shift (manual tranny) | tekmoe | General Yaris / Vitz Discussion | 13 | 12-11-2006 06:27 PM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
