Old 09-27-2010, 03:03 AM   #1
Astroman
Modded Moderator
Astroman's Avatar
Originally Posted by YarisPR View Post
I have a friend who did a dyno run with the CAI & now has the AFE, so I might convice him to to another one with the AFE for us to compare results.
Also I wanna compare my results: costum PVC intake vs the CAI :)
Sounds good to me.
Old 09-27-2010, 08:49 PM   #2
justjesus
justjesus's Avatar
Drives: 2008 Liftback
For comparing results, it would have been better to do it back to back. Keeping all variables as close to the same condition as possible is important for such a comparison. Closing the hood would be good too.
Old 09-27-2010, 11:05 PM   #3
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I'll do what I can but i'm pretty sure Temp,humidity,etc don't change that much here in PR And obviously the same dyno
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 09-27-2010, 07:18 PM   #4
vwtech
Drives: 09 jetta tdi dsg
The CAI has better gains than a short ram.
what kind of gains are we talking about?
vwtech is offline   Reply With Quote
Old 09-27-2010, 08:50 PM   #5
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
The kind that only ones imagination can produce :P oEM ftw lol
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
Old 09-27-2010, 09:26 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
That is simply not true, sorry.
Here is a simple article about the difference:
As pulled from articlebase.com
Short Ram Intake
The typical short ram intake is designed with a few key points. First, it has to be easy to install, and typically only requires standard hand tools. Second, it has to increase horsepower while being a relatively inexpensive modification. A short ram intake is called a short ram because it literally is short. The pipe typically is only about 12 to 18 inches in length, and has an air filter on the end.
Short Ram Intake: Chambered Intake Kits
There are short ram intake kits such as the Weapon R Secret Weapon that offer special technology designed to improve air flow to the engine with technology and tricks that the manufacture claims can out perform a cold air intake. These intakes however are typically as expensive as a cold air intake, except you do not need an air bypass valve. The Weapon R Secret Weapon features a built in tube that increases suction and velocity so the manufacture claims increased performance gains over standard short ram intakes. This is a chambered intake kit. Another chambered intake kit that is very popular is the AEM V2 Intake.
Cold Air Intake
The cold air intake is designed to increase horsepower by relocating the air filter outside of the engine bay, typically putting it into the fender. Because the air filter goes into the fender, the cold air is harder to install, but as it's name implies, it allows the engine to take in cooler air, producing more horsepower. Because of the extra complexity of the cold air intake, it typically has higher cost over the compariable short ram intake. Another issue for some, is that the cold air intake could sit low, and suck up water when running over water puddles. This causes hydrolock, and destroys the motor. There are air bypass valves which fix this, but that adds about another $50 in cost to the cold air intake.
Old 09-28-2010, 09:18 AM   #7
Slick
Slick's Avatar
Drives: '09 3-Dr
That is simply not true, sorry.... Here is a simple article about the difference:
Easy Astro, I was just lightly stirring the pot One may even call it slight sarcasm :)
Old 09-28-2010, 02:57 AM   #8
justjesus
justjesus's Avatar
PUERTO RICO ?!?!?! LOL - Yikes. I hear it's nice there, but never been. I was thinking of the crazy heat wave we have going on in Cali right now. :(
Old 09-28-2010, 07:13 AM   #9
nightstalker
Drives: 08 yaris lb
I have the injen sp series and works great very reasonable price
nightstalker is offline   Reply With Quote
Old 09-28-2010, 07:13 PM   #10
SimTronik
Machinist
Drives: Yaris sedan 2010
Hi, i don't want to start a new thread about this. But if you guys know... Quebec city have long and snowy winters... Well my question is: Can i use an AFE intake during winter season?
SimTronik is offline   Reply With Quote
Old 01-20-2011, 12:26 PM   #11
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
so... im not sure if anyone knows how you would get hydrolock....
yo have to completely submerge the entire air filter....
the only way you would achieve this is if you planned on trying to float your yaris.
you would be surprised how much water your engine could handle.
i like the looks of the afe yes, but i would have to take the aem for the true cai!
Scubaru Steve is offline   Reply With Quote
Old 04-25-2013, 03:17 PM   #12
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I'm not happy with the afe
33.7 mpg in PA
bad is offline   Reply With Quote
Old 04-25-2013, 04:26 PM   #13
Yes.
What don't you like about it?
Old 04-25-2013, 05:29 PM   #14
bad
Winterizing
bad's Avatar
I have a post about my problems I've had with it. I'm not done trouble shooting it but I think that in the end I am going to have to do something drastic to get it to work like use jb weld to make sure all the seals are good. Here is a link to my post
http://www.yarisworld.com/forums/showthread.php?t=37315
33.7 mpg in PA
Old 04-27-2013, 12:41 AM   #15
Monstro
Drives: 2010 Black Yaris Lb
I'm using the AFE and I've been very happy. Nice bump in power and a great sound. Its also extremely easy to clean the Pro dry S filter media.
Monstro is offline   Reply With Quote
Old 04-28-2013, 02:03 PM   #16
bad
Winterizing
bad's Avatar
Hey Monstro,
Did you ever have to do something extra to make sure all parts are sealed? Could you post a couple pictures of your connections please?
33.7 mpg in PA
DIY - AEM CAI (cold air intake) kurokoma-kun DIY / Maintenance / Service 4 08-16-2009 02:56 AM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
AEM Cold Air Intake!!! BulletProofAuto Sponsors Classifieds Area 18 09-19-2006 09:33 PM
AEM Cold Air Intake Toddhata Performance Modifications 18 08-08-2006 03:02 PM
