![]() ![]() Drives: yaris Join Date: Nov 2008
FINAL GEAR 3.7 yaris
any info ...?
yaris Turbo/SC with final gear 3,7 (original 4.3)..
multimakmurperformance.com |
What is the question?
#3 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Where in indonesia are you? I used to live there years ago. I believe he is asking if the final gear is 3.7 in the turbo yaris. Instead of the 4.3 final gear found in the other models... The C54 transmission found in the 1.5l yaris has a final gear of 3.5 The Scion xA transmission (which is also a 1nzfe) has 4.3 The Yaris YR 1.3l 2NZFE has 3.9 The C160N 6 speed from the levin is 4.5 hope that helps....
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
I want a 6 speed
Who said Yaris was slow?
OK,
The US Yaris comes with the C50 tranny and its highway friendly 3.722 Final gear The Yaris TS, and not sure if other Asian spec Yaris have the C56 tranny which indeed has a Final gear of 4.312 Is just that there are 2 different 5spd transmissions used on the second gen yaris around the world. Revoturbo you should be able to determine wich tranny do you have in your car by looking at the badge on the drivers door... where the chasis number is. It should say either C50 or C56 somewhere in that badge. |
ok, will you set that up for me?
Break'em off some.
3.7 will be better for the turbo cars.
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Someone should swap in a unit from the XA and watch their acceleration improve. I bet that gear change in the final drive is worth 3 tenths in the quarter mile.
just got info from my friend (yaris club)
Yaris standard final gear 4.3 shift @ RPM 6500 1st gear 54 Km/H 2nd gear 88 Km/H 3rd gear 118 Km/H 4th gear 162 Km/H 5th gear 208 Km/H Final gear 3,7 (yaris turbo M) shift @ RPM 6500 1st gear 62 Km/H 2nd gear 103 Km/H 3rd gear 138 Km/H 4th gear 185 Km/H 5th gear 230 Km/H Final gear ratio= starlet turbo EP 82 .4EFTE this final gear 3,7 is a must for yaris with Turbo/ SC right.?.
already done by a member here in california.....
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#12 | |
The question for that answer really depends on what you want your car for... For a NA there is no doubt that it would benefit from the shorter gear ratio. However for a turbo Yaris the longer gears will probably be better at least for street use... |
The 04-06 Scion xAs and xBs have a shorter gears, so with an NA car looking to pick up speed from 0-60 that final drive is better. Be warned that a scion transmission will not fit into a Yaris (06+), however I did not try to swap the gear sets - thats a whole other project
![]() If you do swap those Scion gears in, be sure to keep us updated! (You might even be able to sell off your old tall gears to a Scion owner who wants better mileage)
Yes thank You. I got the final gear last week (3,7)
#15 | |
Though in an autocross/track environment the shorter gears would be an advantage....
Toyota starlet Gt turbo has 3,7 too.
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Which Redline gear oil is the best for our Yaris? | stevencyt | DIY / Maintenance / Service | 0 | 03-13-2007 11:11 PM |
