Old 09-28-2006, 02:21 PM   #7
bigsky2
Cousin Vitz
bigsky2's Avatar
Originally Posted by nick1983
Any one of those bolts would be great for grounding. If you want better results you can ground to 2-3 of the bolts. Remember the threaded bolts and holes and not painted. So grounding shouldn't be an issue
I think I'm going to use one of the four lower bolts pictured in the first picture, which hold the plastic trim down. I took out the bolts yesterday and I saw that it was touching the chassis. Pretty good!
I'm only going to select one ground point, as I'm grounding everything to a single point to prevent any new electrical paths to form, which could distort.
Just needs some sanding and it should be good to go.
