Old 03-22-2009, 11:21 PM   #1
YAR1S
YAR1S's Avatar
alignment off?
my old car did this A LOT.
If you've hit a curb recently it may have thrown your alignment off... or maybe uneven tire wear? look at your tires.
-Jen <3
Old 03-22-2009, 11:37 PM   #2
supmet
Drives: 2007 4 Door Yaris
alignment off?
That's my guess. I have an 07 sedan, and the rear is sagging a little, but nothing that would make it pull. Unless you go offroading in the yaris, the suspension should be good for 100k minimum. If you're that worried about the suspension you could feel test it. Go to each corner and push down right above the tire. The car should resist downforce and bounce back up evenly between front left/front right and rear left/rear right.(the back will probably be softer than the front, but that won't make you pull - differences in left/right will.)
low tire pressure/alignment/uneven tire wear(which would almost assuredly mean alignment is bad) would be the first places I'd check.
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 02:14 AM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
LEGATO`` - Photo-Scavenger Hunt LEGATO`` Photo-Video-Media Gallery 1 03-02-2009 10:38 AM
Someone Please Help With SET & Local Dealer Nightmare! sanityassassinv2 General Yaris / Vitz Discussion 32 11-26-2008 11:32 AM
