Old 09-18-2006, 03:43 PM   #37
H2XcapePod
Drives: 07 Yaris LB
Everyone I c runs 205/40's, I can see the variance for 205/45's are just a little bit more but still within 3%. I think I'd like a bit more rubber, call it pothole-a-phobia...
H2XcapePod is offline   Reply With Quote
Old 09-18-2006, 10:38 PM   #38
mhero
Drives: Yaris 5Dr.
mine is 205/45/17
mhero is offline   Reply With Quote
Old 09-19-2006, 05:15 PM   #39
ChinoCharles
Drives: LB
^^^ Hotness. Need springs though.
Old 09-20-2006, 05:04 PM   #40
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
Originally Posted by SimmZ
225/50R17!! Oh my freakin' god!!
You can't put any size of tire you want on a car man! You have to respect the overall diameter of your stock wheel, that's mean, if you put bigger wheels, you must use slimmer tires to get the same overall diameter what your stock wheels. If you don't put the right tire size and get a bigger overall diameter more than 3%, all your gauges will be mistaken and your ECU will also get bad measurements who will result in major problems.
- For stock 175/65R14, you must use 205/35R17.
- For stock 185/60R15, you must use 205/40R17.
i have stock r15, can i get 205/45r17? i just dont like the hard ride on the 40s or do i have to go r16 for 45s?
manborn is offline   Reply With Quote
Old 09-26-2006, 03:42 PM   #41
H2XcapePod
Drives: 07 Yaris LB
Originally Posted by mhero
mine is 205/45/17
Old 09-27-2006, 12:27 AM   #42
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
i plan to put aftermarket wheels and tires. i have been computing the overall dia. based on tire sized a/b-rc. (a*(b/100)*2) + c * (25.4) = dia in mm. then just compute the % to not exceed 3 or 5% from the stock.
by the way, is it 3% or 5%?
also i noticed the yaris sedan and S have a differenent computed dia. 175/65r14 = 583.1mm dia vs 185/60r15 = 604.2. which is 3.6% and 3.5% respectively. Does this mean the ECU for the sedan is programed differently as that to the S?
jeff_o is offline   Reply With Quote
Old 09-30-2006, 11:14 PM   #43
manborn
are u still 34/39?
manborn's Avatar
http://www.yarisworld.com/forums/showthread.php?t=1647
you're better off going with the link below, it will automatically calculate everything for you
http://www.1010tires.com/TireSizeCalculator.asp
17" rims PixieDawn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 09-13-2006 09:07 PM
Lets talk rims....again (help!!) silverRS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-30-2006 01:38 AM
RIMS ON THE YARIS Uglyboyed Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-26-2006 03:02 AM
17" rims + noticable power loss???? bladesmith6 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-22-2006 08:30 AM
rims for yaris thread wushumasterku Photo-Video-Media Gallery 0 06-11-2006 01:44 AM
