Old 03-29-2009, 07:51 PM   #1
mrbond
mrbond's Avatar
Anyone know the part number for this?
I've become convinced that anyone can order just about anything from a Toyota distributor after I found the S ground effects set on the inventory of a dealership online. So does anyone know the part number for the S liftback gauge cluster? You know - the gauge cluster with the tachometer that was only available in the S model?
Thanks to anyone who knows the part number.
While I'm at it, I might as well ask: where does a person find all of these part numbers?
- A Toyota Yaris
- A whut Yaris?
Old 03-29-2009, 07:56 PM   #2
supmet
Drives: 2007 4 Door Yaris
I would check this site out:
http://www.toyodiy.com/
Here's a canadian part number, couldn't find a tach on a US model.....
http://www.toyodiy.com/parts/p_U_200...MVKK_8301.html
Old 03-29-2009, 08:04 PM   #3
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
i think there has been numerous threads on this topic and how it wont work on many levels
Old 03-29-2009, 08:07 PM   #4
mrbond
mrbond's Avatar
Well, I'm prepared to swap a lotta lotta wiring and whatnot. I'm not really concerned with how it won't work, but rather what I need to make it work
- A Toyota Yaris
- A whut Yaris?
Old 03-29-2009, 10:19 PM   #5
kustom play
Drives: 07 liftback
it wont work, mileage and info is stored in the cluster not the ECU like we believed
so if you swap it your mileage will be off, i believe you need to swap the ECU's and get a new wire harness
ohh the gauge cluster is not cheap also i think like 400+
so cluster, ECU, wire harness,
its why nobody on here has done it...
people have tired, and came up with it not working
Old 03-29-2009, 10:23 PM   #6
mrbond
mrbond's Avatar
Like I said, I'm ready to spend a lot of money doing this swap. If you want something bad enough, then you should just go ahead and get it.
All I wanted was the part number. Guess I'll just go to a Toyota dealer and work with them.
- A Toyota Yaris
- A whut Yaris?
Old 03-29-2009, 10:41 PM   #7
Sparks Toyota-TRD
Drives: Toyota/Scion
Let me look at this tomorrow and I will see what I can find for you!
Also check www.car-parts.com for junkyard finds!
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 03-29-2009, 10:48 PM   #8
supmet
auto with a tach- 83800-52E80
manual with a tach- 8380052E90
Here's a forum where someone describes problems someone had swapping, but no one replied
http://www.the12volt.com/installbay/....asp?TID=97796
Also, they are 470 each at my local toyota dealership
http://www.crowntoyota.com/
click on parts and search the part number
Old 03-29-2009, 10:52 PM   #9
mrbond
mrbond's Avatar
Well it was certainly helpful.
I have a liftback, and the part numbers you gave were for a sedan. It's a good start for me though.
Thanks!
- A Toyota Yaris
- A whut Yaris?
Old 03-29-2009, 10:53 PM   #10
supmet
Thanks!
lol... let me try one more time... haha
edit: hmmmmm I checked through toyodiy, and I can't find a US 3dr with a tach
Old 03-29-2009, 11:55 PM   #11
The one for the 08 S liftback is:
83800-52P10 (no ABS)
83800-52N70 (w/ABS)
Old 03-30-2009, 12:50 AM   #12
IllusionX
Drives: 07 Yaris Sedan Aero
if you have the money to spend, why not sell your yaris and get a 09 RS (S) ??
Old 03-30-2009, 08:01 AM   #13
mrbond
mrbond's Avatar
Because I don't really like the new facelift, and $700 is way less money than $8000 after trade-in.
- A Toyota Yaris
- A whut Yaris?
Old 03-30-2009, 10:18 AM   #14
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
Tim
junkyard is best bet seeing as TOYOTA cluster has to be called in and vin# verified.....
Old 03-30-2009, 12:38 PM   #15
supmet
Hey I had a thought about this. Feel free to call me crazy and move on, but I thought I'd throw it out. So if the mileage is stored in the gauge cluster, and you don't want to deal with all of that junk - do you think an electrical engineer or someone could remove JUST the tach from the cluster you buy, and put it in your car? I haven't ever looked at the boards behind on a yaris with a tach, but if they are separate boards(tach and rest of cluster) and they have separate wires, it might be easier to just pull the tach and have a custom install. You get an in gauge tach, and get to keep your mileage.
Old 03-30-2009, 01:45 PM   #16
kustom play
Drives: 07 liftback
or just get a small aftermarket tach and save yourself 600+ to put into other mods?
Looking for part number for JDM RS or EDM TS. Crandall General Yaris / Vitz Discussion 0 03-16-2009 11:11 PM
Part number on rear skirt needed, who works at Toyota? Danish Yaris DIY / Maintenance / Service 0 02-07-2009 05:52 AM
part number/ price for 60/40 seat nerd_vitZ Cosmetic Modifications (Exterior/Interior) 7 12-27-2008 02:08 PM
Anyone know the dealer part number for the 09 S kit 808yarisLB New YARIS Purchase Forum 5 12-08-2008 10:38 PM
HELP: JDM Armrest Console Box part number GabL Cosmetic Modifications (Exterior/Interior) 7 10-24-2006 11:12 PM
