Old 04-03-2009, 07:02 PM   #3
gwasabi
Drives: 07 Blazing Blue LB
cold idle isn't solved this is due to the loop mentioned above and the actual TB opening being alot wider than the stock TB. at cold start it will usually rev up to about 1.5K then back down to 700-800 RPM
gwasabi is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
In need of an original throttle body!!! URGENT toto1881 DIY / Maintenance / Service 0 03-28-2009 03:54 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
