Old 04-05-2009, 11:50 AM   #5
MUSKOKA800
MUSKOKA800's Avatar
Originally Posted by jeff69dini View Post
just wondering as I have factory P175/65-14 now and was wondering about clearances and stuff like that?
thanks in advance
I dought it considering my 175/65/14 winter set-up are far smaller than the stock 185/60/15's by about 1" total hieght.
My suggestion, go to TireRack.com and find your stock tire or another of similar size. Click on spec's and see the chart for it's diameter. Then find the tire you wish to change to and do the same. Keep in mind that actual measurements vary from manf. to manf. for the same size. Try to find the spec.'s for your actual brands of each size.
Anything close will work but keep in mind the difference will throw off you speedo and odometer accuracy. You can use a GPS unit to find your actual speed.
205/50/15 tires on the S sedan 15" standard alloys??? CASTREX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 11-16-2006 07:41 PM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 11:12 AM
