Old 04-23-2009, 12:07 PM   #4
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
There's actually quite a few empty fuse spots on the master fuse block behind the drivers-side dash area, the problem is getting the main fuse block detached to access the plugs on the rear to wire up the 'far side' of those unused fuse slots basically requires taking out the entire dash, AND the steering column near as I can tell.
WolfWings is offline   Reply With Quote
