Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Hawaii
Old 04-26-2009, 04:46 PM   #109
gwasabi
Drives: 07 Blazing Blue LB
Man Devin, You got to it a lot earlier than i could T-T only if I had the money for all of it hahahahaha.
Are the rods and pistons all original custom made or are they mass produced? I was looking all around for them but I couldn't find ANYTHING for the 1nz builds?
I originally wanted to go N/A build but i dunno I'm really considering turbo now hahaha
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 04-26-2009, 05:30 PM   #110
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
um they do mass produce it the rods are actually for an xb and block needs to be notched on the bottom alittle the pistons come in standard size 9.0 comp or a .5mm oversized in a .5 mm. go turbo alot more fun then n/a but rods are made by crower and the pistons are made by cp. u figure a simple setup with boost on a stock motor would be good but if you decide to up the boost later you need to build the bottom end hence why ive been talking with crower to see if they could build a 1nz bottom end along with actual rods that dont have to notch the block that will work for the yaris. he has made me custom pieces before for other builds it just takes time for them to come around with it but if this all turns out well ill prolly take the other spare motor i have build it and start selling fully built n/a or turbo motors for people in exchange for cash and there motor. depending on how much the build comes around to in price wise. i might try make a more straight shot intake manifold without bends to see how that comes out as straighter the better which isnt hard ive made itbs by myself so welding a intake pipe together shoudlnt be difficult
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 04-26-2009, 05:34 PM   #111
gwasabi
Oh so its a XB's setup then. Thats not too bad either. well I guess i'll ave to do a little more research on it hahaha
Serious Business...
Old 04-26-2009, 05:36 PM   #112
battleversiontc
well the xb and the yaris have the same motor just setup differently internals all the same i think the rods are just because there thicker thats why you need to notch them
Old 04-26-2009, 05:49 PM   #113
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Well, i don't think motor swaps are for pussies, although i will say that in japan motorswaps and larger displacement swaps are not done very often. This project if it gets done will be impressive. Not all motor swaps add weight. Are you saying that when all is said and done your car will weigh the same as when you started?
Ultimately, as do the tuners in Japan, I prefer my cars balanced. Power is nothing without control.
Good luck.
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 04-26-2009, 05:51 PM   #114
anonymous user
Drives: 07yaris
I thought hte newer xB's have larger 2.4L engine?
Old 04-26-2009, 06:13 PM   #115
gwasabi
The newer XB uses the TC engine i think. I was thinking maybe grabbing a XB 1nzfe anb just popping it in like a exchange or soething hahahaha
Serious Business...
Old 04-26-2009, 07:28 PM   #116
battleversiontc
the newer xb does use a 2.4l but the older one uses a 1nzfe motor
Old 04-26-2009, 07:37 PM   #117
battleversiontc
well this aint japan so it doesnt do any good mentioning it. but bigger displacement motor like the tc will add weight. like being said if you took a honda hatch that came with a 1.5l motor and added a h22a perlude motor how will that not add weight hence why they change front brakes and front suspension off the car it came off of to compensate for the weight difference now if your swapping a smaller displacement motor like a 1.3 i agree it wouldnt add weight. thats like dropping in a 350 chevy motor but later upgrading to a 572 how will that not add weight. add yes motor swaps are for pussies because they cant build what the car came with so they have to add a bigger motor in order to compensate for there lack of ability. control you can still have control on a motor swap its called taking the front suspension off the original car and swap it out to the suspension that came off the car with the motor that your swaping in the balance will still be there thats how you obtain the balance back. yes car should weigh the same when im done all said and done its called trimming the body fat everything that is lighter will drop in weight there for compensate for some of the parts that arent lighter
Good luck.
Old 04-26-2009, 07:53 PM   #118
anonymous user
Drives: 07yaris
^^Wow. Soo hostile. I think you missed all of what I'm trying to say. Thank you for also being very condescending and childish. In Japan, they like balance due to the fact that the 1/4 mile, 1420, drag racing is not popular there. Another reason why they don't do swaps. I don't know what i said to piss you off, but anytime you wanna race me, let me know.
But I only race legally, so you'll have to wait until July.
I'd love to see you handle 600whp against, well i'll pick something with less power. Maybe even just my yaris. I don't race in straight lines though.
Old 04-26-2009, 08:13 PM   #119
battleversiontc
im not trying to be hostile and im not pissed just trying to state something and i dont build cars for 1/4 mile i build mine for street runs not 1/4 mile no sense since we have no quarter mile i still can hold wot throttle if you like race something with turns we can do h3 on to like like off ramp turn ill still hold wot and she will still hold. but im sorry if you took it as me being pissed off and such but im really not and if you do want to test my tc against anything you bring we can do a grip run up tantulas at night with no headlights
Old 04-26-2009, 08:39 PM   #120
gwasabi
ooooo I would so take you up on that offer for the grip run if i still had my hachi!!!! T-T I miss it!
Serious Business...
Old 04-26-2009, 09:10 PM   #121
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
no headlights!? isn't that dangerous.... lol
Old 04-26-2009, 10:01 PM   #122
battleversiontc
not really that dangerous if you remember the turns by memory
Old 04-26-2009, 10:13 PM   #123
gwasabi
yup yup plus your eyes adjust quickly if you know what your doing hahaha
Serious Business...
Old 04-26-2009, 10:15 PM   #124
battleversiontc
no need headlights jus open the eye bigga hahaha or you can always use my other method night vision goggles me and my friends use them when we use to live in cali for the vegas runs at night just turn off the lights and go
Old 04-26-2009, 10:17 PM   #125
gwasabi
I only remember coming in from light side though
Serious Business...
Old 04-26-2009, 10:17 PM   #126
gwasabi
I think dark side is a little more dangerous since most on oncoming traffic come from light side
Serious Business...
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
Sedan Styling thread v.2 tuckevalastin Cosmetic Modifications (Exterior/Interior) 254 09-29-2022 07:05 PM
Expressions and Explanations thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 11-09-2008 05:55 PM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
