Old 04-27-2009, 04:15 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by at3GG View Post
Seriously? I guess I'm sorry for asking a question. This is a discussion forum...you apparently know the answer so why would i google it? Kind of takes away from the whole forum idea doesn't it. Dont really care to know the answer anymore, good luck to whoever tries any of this out.
guess how i learned about atkinson cycle engines... ;) think it was on a forum?
Originally Posted by www.wikipedia.com
The 1NZ-FXE is the earliest 1.5 L (1496 cm³) version built in Japan. Bore is 75 mm and stroke is 84.7 mm. It features forged steel connecting rods and an aluminum intake manifold. The engine has a high physical compression ratio of 13.0:1, but the inlet valve closing is retarded. The net result is that the engine has a greater effective expansion than compression – making it Atkinson cycle, rather than the conventional Otto cycle.
so, just because it has a physical compression ratio of 13:1 it does not mean that the pistons/rods are subjected to typical 13:1 compression forces. in fact, the prius only revs to 5000rpm, so you'd want to take into account these factors.
it's not a 'SLAP IN SOME PISTONS AND RODS FROM A PRIUS YO!' solution.
