Old 04-23-2009, 09:25 PM   #37
chasd60
Drives: 2008 Yaris HB Auto
Fill up early in the AM when the gasoline is the coldest
http://ts.nist.gov/WeightsAndMeasures/upload/B-015.pdf
Slow flashing bar begins with 1.6 gallons remaining
Fast flashing bar begins with 1.1 gallons remaining
chasd60 is offline   Reply With Quote
Old 04-29-2009, 02:35 PM   #38
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
There are a few stations that are like that here, all I do is put the gas cap under the handle to hold it up until it stops.
Probably not the brightest idea, but it works...
Cheers! M2
When I was a kid my dad did work that required driving his 'big truck' interstate. The thing held something like 300 gallons of fuel in three tanks, which of course takes a while to fill. The pumps at the station where he always filled it didn't have those little levers (IIRC few did back then) so he'd widdled a little piece of wood to fit exactly under the lever and hold it in place. When he was done he'd stick it up in the mortar lines between the bricks behind the sign telling people not to smoke and to turn off their engines. The station is no longer there (it's been an empty lot ever since they required double walled tank upgrades, which they couldn't afford, so they closed), but it's an interesting memory.
twowheels is offline   Reply With Quote
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
