#19 |
Drives: 2008 Yaris Join Date: Oct 2008
Brian is especially correct about hypermilers having different needs from tires than the usual consumer. A tire which is inflated to 60psi is probably not safe for use at speeds over, let's say, sixty miles an hour. To the hypermiler such speeds are beyond the pale, and hence for them a higher pressure is safer.
Gene |
#20 | ||
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
This is the fuel economy forum. For discussions on autocross please see the racing forum. If you can get any of the folks over there to test anything other than a butt dyno please let me know.
supmet, I'm not sure why you continue to hang out in the fuel economy forum as you don't seem to have much interest in it and you consistently deride the practices of those that do. You seem to thrive only on misinformation and alarmism and continue to do so in the face of mountains of data and practical examples that contradict you. Please feel free to frequent other parts of the forums that are more in line with your personality and personal desires.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#21 | ||||
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Its pretty much elementary physics. You aren't absorbing as much energy with the tires = more energy gets transferred into the suspension and chassis. To completely write this off is irresponsible. Quote:
And I like getting better gas mileage. That's why I post here. I just like to get the WHOLE story - not the tunnel vision story that hypermilers THRIVE on. |
#22 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
here's a thought... go talk to the guys at the tire shops, see what they say about tires that are over or under inflated... ask them if it affects the mileage of the tires..
I have no intrest in what the local kids are doing and what they think work.. I want facts... I have yet to have my tire suppliers tell me to double my air pressure to increase my mileage... why? because what I save in a year running on over inflated tires i'll spend on tires the following year when these are pooched. tire pressure is very important... how do i know? I'm a mechanic (motorcycle) Sure most of my background is racing, bikes and offroad but tires are tires people. The number one cause of tire damage on motorcycles is caused by incorrect tire pressure, cupping and tire deformation is most common. I can't tell you how many times owners have come to me complaining of poor hadling or poor tire life...guess what...tire pressure is usually the cause or part of the cause. then there is the traction issue, with a motocycle even 2-3 psi cam make a HUGE difference. Usually not as noticable at slow speed when the foot print/contact patch is the largest and tire temps are cooler. The same applies to Auto tires though A tire at 60psi ..what is that at highway speeds when the air temps increase...its dangerous. if it were not for the steel belts in the tire holding it together it would likely explode when you hit a pot hole. Do you really think the tire remains the same shape at slow speeds as they do at highway speeds/ I enjoy the great fuel mileage, but come on... if it means that much to you go with a smaller set of 13" pie cutter tires like the geo/sprints had. BTW a simple tire tread depth gauge will easily show you what over inflating tires does as far as uneven wear.. you can't always see it just standing there with you arms folded staring at the tire sayin nope no wear yet! Most people never notice tire cupping or a shifting belt until they have a bald patch or the tire deforms and starts causing vibrations FWIW I followed the mileage group on the Ford focus forums... I had an 03 with 155km... I JUST got my second set of tires last fall at 120,000km. I ran 35psi The hypermilers on the same sight running even 44-50psi were getting 60-80k km to a set. figure that into the math... with the 1-2mpg less I may have got and what I saved using synthetics etc.. I bet it cost more buyin tires every 2 years for them.
The early bird gets the worm, but the second mouse gets the cheese. Last edited by 07WYarisRS; 05-03-2009 at 06:09 PM. |
#23 |
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Strange, when I took my Cobra through the Bondurant school of high performance driving they REQUIRED that my tires be inflated to sidewall max. Not negotiable.
I have the stock Goodyears that Toyota puts on the 15" steelies. My three-door hatch is a hopeless, hapless disgusting pig in the corners with 32 psi in the tires. The TRD rear sway bar helped some, but running 51 psi front and 50 psi rear makes it dry corner like it's on rails. That's only six psi higher than sidewall max. These tires are wearing evenly so far as well. I'm not saying that any old tire can accomplish that though. Also, most of the pothole related tire failures I've seen were the result of the sidewall being pinched (crushed) between the road and the wheel. Higher tire pressures should make that harder to accomplish. Last edited by Rick; 05-03-2009 at 06:17 PM. Reason: Brainfart ..... wrong tire brand |
#24 | |
www.tirerack.com If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear. But its all a conspiracy huh?? I'll bet you thebarber and supmet work for the big oil companies. |
#25 |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
I think Obama is behind it all.....
#26 |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
#27 |
i was under the impression you raise the pressure a bit so the sidewalls flex less under heavy cornering...im kinda surprised they put it at the max....but maybe the tires have a level of safety built into the "max pressure"?
#28 |
...actually that's not true. A good tailgater drives at least two, maybe three cars beyond their victim. You have to have your empathy dailed up to ten to see where they might brake so that you can brake before they do.
If all you do is look at the bumper of the person ahead of you it's a matter of time before you feel it. Gene |
#29 | |
If you're talking catastophic failures I could not say. If you're talking belts breaking, that's another topic. Don't know if higher pressures would help or not. I pays my money and takes my chances at factory pressure settings. |
#30 | |
I have very little experience with tire wear. I'm still on my original tires on my Yaris, and I had two sets on my old Elantra. When I first got the Elantra it had new Potenza G009s on it. I kept them at the pressure Hyundai recommended. After a few months the outer edges wore down quite a bit. My next set of tires were Falken ZE-512s. I played with the pressure until I found a comfortable psi, which was 40 psi. After 63,000 miles the treads had barely worn down at all. I found the ride in the Yaris to be comfortable at about 42 psi on the stock Eagles. 9,000 miles in all is well. I've been consulting this site for tips: http://www.carbibles.com/tire_bible_pg2.html Scroll down about 2/3 of the page. Your results may vary! |
#31 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
#32 | |
#33 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Just an observation:
The TPWS in the Yaris seems to trigger somewhere down around 25 psi, and there doesn't seem to be any upper limit. (purely a limit warning system and not an active monitoring) Thus for myself, I am more concerned about letting them get too low, than running a few psi high. |
#34 |
I set it the way Toyota likes it; the way I like it
I think I'd rather be warned after losing 6 or 7 lbs vs losing 36 or 37 lbs (running 32psi instead of 60psi)
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 05-04-2009 at 02:26 PM. |
#35 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
![]() I keep mine at 36 cold to increase sidewall stiffness (for cornering), and decrease wind movement. If you corner harder, the outer edges will wear the same as the centre. Each to his or her own, however. I set my car the way I like it, and fully hope everyone else does the same (i.e. how THEY like it, not how their friends tell them it should be) |
#36 | |
50 MPG or BUST!
Spoken like a true Rhode Islander! I doubt that any of the belligerents here will ever agree on this issue, or more importantly convince the other side. I recognize that both sides only want what is best for us fellow yaris drivers and want to share their info and educated opinions on the topic. But at the point where it shifts from a positive sharing of information and opinions to a negative, mudslinging argument (from whichever side it may be...) I second the solution of "to each his own." ![]() On a side note, I personally keep my OEM tires at or around 44 psi. As weird as it is, I prefer the comfort of 44 as opposed to 32, and that is why I keep it there. I have not noticed any uneven or untimely wear on my tires, although as someone mentioned previously, I am not measuring the wear scientifically. I have noticed a significant change/decrease in fuel economy the times my tires have been around 32psi, so I also second Bailout. (And that is my contribution to forming any kind of unscientific consensus.) |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 06:40 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| NEED USED TIRES!!! | natethegreat38 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-06-2008 12:11 AM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 01:23 AM |
