Old 05-03-2009, 03:41 AM   #1
What can I do with a bunch of these LEDs?
Took apart my projector lights just to fix the halo LEDs that cad come loose. So I decided to get rid of the stupid spaceship LEDs too.
So now I have 6 of these lil wedge LEDs:
Any ideas where I could use them to replace some stock regular bulbs?
Old 05-03-2009, 03:51 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
number plate bulbs
map reading bulbs
throw them away
Old 05-03-2009, 10:30 AM   #3
number plate bulbs
map reading bulbs
throw them away
Hmmm yes those could work, gonna have to try that... The LEDs themselves are too big to use for the AC controls, sadly (they're pretty powerful, cast an almost usable amount of light when they were in the headlights)
position lights in the headlights
On stock headlights yeah but I have the projector ones, different story...
Old 05-03-2009, 11:59 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I like the suggestion of the running light type illumination in the headlights. You could wire them together and use them as a dome light as well...
― Thomas Paine
Old 05-03-2009, 12:37 PM   #5
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
These also work for the side blinkers. Or you can try to sell them.
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-03-2009, 01:29 PM   #6
Yep, those two solutions tempt me most
Old 05-03-2009, 05:59 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
don't use them for side markers. they will only be very visible at 90degrees, and barely at other angles.
Old 05-03-2009, 09:50 PM   #8
xen555
xen555's Avatar
Drives: 3 DOORS LB
i will use it to replace the back up lights... to see better when im in reverse
that will be useful
xen555 is offline   Reply With Quote
Old 05-05-2009, 02:47 AM   #9
that will be useful
Unless you have MANY LED's, using them for reverse lights will only be detrimental. Trust me, my friend works with LED's, and his reverse lights are LED's. Looks good, but does not illuminate the road very well.
Only places (for the sedan at least) that accept these wedge/194 types are the map lights, license plate lights, and the trunk. OR you can send them to me, I owe my gf two for taking back the ones I bought her for her map lights . What, I bought her the dome lights and a sub. LOL.
Old 05-05-2009, 02:58 AM   #10
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
make puddle lamps for the car ;) I think it would bring out a nice high-class feature to the yaris.
808_Yaris is offline   Reply With Quote
Old 05-05-2009, 03:01 AM   #11
gwasabi
Drives: 07 Blazing Blue LB
I second puddle lamps, That's what I planned to do later. I would have the puddle lamp wired to the dome so that when the doors are open the led lights up and turns off when alarm is armed. Also did you figure out what kind of LED the Halo lights use?
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-05-2009, 03:05 AM   #12
808_Yaris
Where is Oahu?
808_Yaris's Avatar
^I had the same idea!! maybe we can work on this and come up with the best. I heard that some halo's are made out of the cold cathode lights.
Old 05-05-2009, 10:01 AM   #13
Hmm good idea, drill a small hole on the bottom of the side mirrors... though passing wires through the door jamb is a bit PITA
The halos use two little tiny LEDs each, even smaller than regular 3mm ones, definitely room for improvement...
Old 05-05-2009, 03:11 PM   #14
808_Yaris
Where is Oahu?
808_Yaris's Avatar
go for it!! i'd like to see the results
Old 05-13-2009, 04:28 PM   #15
severous01
that's a 194 bulb...you can use it just about anywhere on just about any car.
specially license plates, blinkers, older dashes and shifters, turn signals...the list goes on. i'd keep them...and if you get an old jeep or something put them in there...lighting sux in older cars
or if you're throwing them away ship them out to me...i'll use them in my jeep or camaro.
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Gauge Cluster LED's Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 11 01-08-2009 12:59 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
Cheap LEDs Interior and Exterior jamal1984 Cosmetic Modifications (Exterior/Interior) 10 04-11-2007 11:08 AM
