Old 05-04-2009, 11:02 AM   #23
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Noogie,
You probably will never be able to fix the CELs at startup unless you can reflash the ECU to scale the larger injectors (which we cant currently do). You need injectors that are a little smaller to get rid of that. The car has a +/- 25% fuel correction, so you need injectors that flow no more than 25% more fuel than the stock units to avoid getting CELs.
10.5:1 is good, If you can get a fuel controler on there to lean it out a bit you will be in decent shape.
How do I cure a lean condition? LtNoogie Performance Modifications 101 03-21-2013 11:40 PM
RC Engineering injectors will not fit our engine with the current setup LtNoogie Performance Modifications 14 06-18-2009 03:38 AM
Spark plug diagnosis and lean condition camelll Forced Induction Forum 33 05-09-2009 12:48 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 01:18 PM
