Old 05-08-2009, 03:00 PM   #11
427chev
Drives: 2009 Yaris with TRD parts
I've aleady won my argument with you, based solely on that fact that you resorted to (baseless) insults in lieu of a credible response that included objective evidence to back your "opinion."
Time and time again, objective evidence proves my point. In fact, the article below noted that the car designed to run on 87 octane actually ran WORSE on premium. That is not the first time I've seen that happen. I suspect that premium's slightly slower burn time might result in compromised combustion in some engines that are designed for regular fuel.
http://www.caranddriver.com/reviews/...ature/(page)/1
http://www.consumerreports.org/cro/c...l-dollars-406/
"Don't use premium fuel if you don't have to. If your car specifies regular fuel, don't buy premium under the mistaken belief that your engine will run better. The only difference you'll see is about 20 cents more per gallon. Most cars are designed to run just fine on regular gasoline. Even many cars for which premium is recommended will run well on regular. We have found that the differences are imperceptible during normal driving. Check your owner's manual to find out if your engine really requires premium or if you can run on other grades."
427chev is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
