Old 05-08-2009, 11:11 PM   #35
there will be more threads sticking thru the top of the strut top because the df's will be shorter than stock springs
the spring/strut combo up front is compressed together with a nut and cap that are separate from the nut you remove in the engine bay
the process is 100x easier w/ an impact wrench...i used one installing my coilovers and had no issues removing the top nut.......however i sprayed every nut w/ penetrating lube the day before the install so all the nuts would crack easily...
hope the rest of your install goes smoother...!
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
spring install help asap! DELETE tristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 02-18-2009 01:30 PM
Suspension install: Spring Compressors? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-18-2007 10:59 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
