#19 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
While you certainly had a 72.25 MPG segment your fill up was only 1.557 gallons after 112.5 miles. In the world of logging and record keeping only a half tank or more constitutes a tank. In our car this means a fill of at least 5.55 gallons. Still, that was a great segment! Keep up the good work.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#20 | |
#21 | |
#22 | ||
![]() Yeah, drafting wasn't that bad. I see people drafting closer than I did. Oddly enough, some of the trucks I see drive faster than I do, so I can't even draft them ![]()
#23 | |
#24 | |
Good job!
#25 | |
rarer than JDM -1 of 1!
Thanks for the support, i wish i had someone locally here that could do a ride-along and give me more tips. (hint,hint)
#26 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
One of my coworkers just had to tease me about modding the Yaris to
try and make it a little more aerodynamic. Smooth hubcaps, tiny antenna, and partial upper grille block. Hey, its a good hobby... And I have been hitting 45 Mpg averages on the way to work lately. But he did slip up and tell me about riding his motorcycle down the state 2 lane highway to avoid the freeway merge and related city traffic. Well, I tried it on the way home Friday and it does take an extra 10-15 minutes, but 52.5 Mpg! and beats my all time record for any trip. I'm not sure the indecisive drivers in the larger towns are worth the trouble to take that route every night, but it's good to know I have more capacity to set some higher trip records. Not only does my modded Yaris beat his motorcycle mileage on that route, it even carries my mountain bike while doing it. Love that little car... |
#27 |
Wow, 52.5 for the tank! Sweet! I'd take that route over the 45mpg route any day.
#28 |
Just a quick question: I just drove 25 miles today after a great effort yesterday,and the first bar de-illuminated already. Was that a result of filling up too soon? I can't figure out why else that would happen?
#29 |
The fuel bars are about as accurate as a magic 8 ball.
#30 |
Something similar happened to me after I filled up after the first bar went off. Now sure why it does this.
#31 | |
Is now a Corolla S Owner
It is impossible to fill the tank to EXACTLY the same level each time, and that is one of the reasons why gas mileage cannot be accurately determined on just one tank of gas. You need to average several consecutive tanks to get a true picture. Tomster |
#32 | |
#33 |
now in HD
trying out "hang time" rather than just backing off the throttle by a lot. dfco doesn't work well for me because my auto's gearing is crap for dfco-coasting in 3rd (can't do it in overdrive/4th successfully for some reason). so can't wait to see this tank (no scangauge to see impg and trip mpg yet). i know it's highly unscientific, but i've already noticed less of a drop in the gauge alone.
'03 2az camry btw. not yaris.
#34 |
Kaotic and Bailout,
I don't know if you're following this weird tank I'm having, but i hit 75 miles, and the second bar went out on my gas gauge. I've never seen it that low. I'll be sure to never fill up early again, i might get these weird results that will skew my data. *Edit, just read your post and yarisownersdad's post as well* |
#35 |
Yeah, run this tank to about half life, then top off. Did you use the same brand on this tank as you always do, or did you go with a cheap-o brand?
#36 | |
I'll keep this thread updated. I definitely want to get this gas out of this tank, but i don't drive often enough. |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
| Toyota Yaris achieves over 84 mpg in MPG Marathon | tk-421 | Off-topic / Other Cars / Everything else Discussions | 5 | 11-17-2008 07:41 PM |
| Toyota Yaris MPG Review at www.mpgomatic.com | aca72 | Fuel Economy Forum | 23 | 10-31-2008 03:59 PM |
