#19 |
![]() ![]() ![]() Drives: Black '09 2dr HB Join Date: Feb 2009
Everyone's saying not to use armor all- I'm going to go to a store again and buy the Meguiar brand for my dashboard. But what do you guys suggest for glass wipes? Same brand? (no, I don't clean at home, so I don't even know the best household cleaning products) And I would like wipes not spray and rag. Any recommendations?
#20 |
BTW you can use claybar on the glass if the water residue is really bad.
#21 | |
How to remove water spouts....
Mix 1/2 water and 1/2 white distilled vinegar Use Micro rags...go after the water spots in circles pressing hard... the spots will come off.... |
#22 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Any new suggestions??
I've tried: Windex CLR Vinegar (mixed and straight) WD40 (just made more of a mess) 0000 steel wool (with all 4 of the above and dry) razors (again, with all 4 "cleaning agents and dry) gasoline alcohol brake cleaner, carb cleaner The window seals can't take much more, so I'm gonna clay bar it next. If that doesn't worked, I'm pretty sure the water spots somehow etched the glass. They aren't normal water spots, I can get those off with windex and a little elbox grease. They are smaller and more faint, and apparently impossible to get off. off topic: I spilled some CLR on the concrete floor, and it instantly bleached spots into the concrete... that is scary stuff. |
#23 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Rain X
The early bird gets the worm, but the second mouse gets the cheese. |
| electric water pump help! | mandriu | Performance Modifications | 39 | 10-24-2009 02:56 AM |
| Racing Spots | blake111887 | NY / NJ/ CT / PA | 10 | 05-17-2007 08:07 PM |
| Flat Spots | YamilR | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 10-22-2006 08:13 PM |
| [Detail] [as to make ] Auto Laudering | Sérgio Barros | Wash, Wax, Detailing, Exterior Repairs | 4 | 08-22-2006 03:56 AM |
