Old 05-11-2009, 01:28 AM   #1
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
i think flex-a-lite is a very good brand as well, its a good choice parmas.
since it comes with a fan controller, you could skip installing an external controller like what i did. am using a pivot super temp here.
just curious, wouldn't you rather have a dedicated cooler for each engine oil and transmission?
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 05-11-2009, 03:40 AM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
You are probably right in saying this but you have to consider the limited space I have in here. I think this oil cooler with it's active cooling is capable of keeping temps as low as possible I can get. Also it would be rather more expensive to get 2 independent oil coolers than a dual circuit one.
Re: ceramic coating... I done some research and there are many that say is a good asset to own heat management. Here is quite difficult to find someone to do the job for you and I don't wish to risk sending all the parts abroad and never come back! Although I really wish this coating I will keep you updated if I could find one somewhere...
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 12:43 PM
cali yaris built motor cali yaris Performance Modifications 83 09-04-2009 12:08 AM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 03:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 11:58 AM
