![]() ![]() Drives: None. Join Date: Feb 2009
Fuel Pressure Regulators and setting meters?
I just trying to learn a little more about fuel systems, but i have an idea what the regulator does. What is the point of the "setting meter" other than showing the fuel pressure?
http://www.more-japan.com/product.ph...cat=539&page=1 ![]() In this case, let's talk about SARD Fuel pressure regulators and their "setting" guage. Someone explain this part of fuel systems to me. Thank you.
The gauge shows the pressure visually so you can make adjustments quickly, without having to read it from management software, etc.
Will this work only for the Sard FPR or others as well?
Bathroom + Laptop = <3
im assuming its universal and you can tap it in anywhere....
A gauge is a gauge, as long as the fittings work. We ended up putting my gauge at the end of the fuel rail - no need for a line or a bracket that way.
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
The gauge shown appears to be the one used to set the fuel pressure on the dyno while tuning and not one you'd have installed constantly (or be able to view constantly since it's in the engine bay).
a standard (electronic) gauge has a sensor attached to a sending unit which then sends the data into the gauge in the cabin. so yes there is a difference between a standard electronic fuel pressure gauge and the "setting" fuel pressure gauge. |
I have a regulator (which sets the pressure) and a liquid-filled gauge off the fuel rail, in the engine bay. I'm assuming it's a mechanical gauge.
#8 | |
l33t3st Asshole
simply for setting the fuel pressure, not for monitoring fuel pressure. |
well, if you sat on the valve cover and leaned way over, mayyyybeeeee you could watch it
#10 | |
l33t3st Asshole
![]() what's the point if you can't see it? |
Here's my set up:
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Garm, what pressure are you setting your system to at idle? Is your regulator boost compensating?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
No, it's a fixed pressure. It's the injectors job to squirt the correct amount of fuel. We have it at 40 right now, but if the injectors max out we may end up with a higher pressure. Not done tuning yet!
#14 | |
l33t3st Asshole
might as well gut the car, ligthen the wiring, and re do the ENTIRE fuel system while you're at it.... research time.
#15 | |
l33t3st Asshole
reason I said the other two things, is I'd like to do those at the same time. |
#16 |
l33t3st Asshole
hmm interesting.
#17 | |
I expect that at my 6psi full boost pressure that my fuel pressure will go up 6psi and keep me at a nice AFR.
