![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
Seatbelt Temp Chime turn off option
So since I have a harness, I was trying to figure out how the hell I'm going to turn that friggin chime and seatbelt warning off. This was my solution.
The Seatbelt On and Off Switch. ![]() I used the existing AUX jack because I have no use for it abnymore since my stock one is broken and I have a new aftermarket HU anyway.
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
37HSSV
DIY! Lots of people could benefit from this mod!
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
DIY is located here: http://www.yarisworld.com/forums/showthread.php?t=3587
37HSSV
HurraH!
Give Me Resonance
Where did you get the switch that fills up the blank slot exactly.
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
SIPNDEW
goodness, this thread pops up a lot. howabout go to the dealer, 15 mins later free of charge, its gone
pull the plug out of the seatbelt latch
problem solved
No dealer around here would disable an important safety feature like this. mikenacarato, are you sure?
SIPNDEW
positive, even says so in the owners manual. plus, ive had it done at my dealer already.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Seatbelt extension is the easiest solution. Dealership gives them out for free (written in your owner's manual), nothing to reprogram, just plug in and tuck extension between seat and console.
the dealer wont do it on the driver's seat.....
you should put a sticker that says "Ejection Seat" above it
#14 |
are we all ignoring the easy solution of unplugging the actual switch that goes to the seatbelt latch?
#15 |
SIPNDEW
#16 |
if you unplug the switch at the seatbelt latch, don't you get a flashing seatbelt sign or something like that?
#17 | |
so. if your dealer won't disable the drivers side warning for you (which is possible, per the toyota service manual) you can do this: ![]() put a 20Kohm resistor between pin 3 and 4 under the seat
#18 |
Interesting... Will that mess with the airbag deployment at all? The guy that sold me my car told me the airbags will not deploy if the passenger isn't wearing a belt. He said you are worse off if the airbag were to deploy that way. Probably
| seat belt chime disable? | Lewis | DIY / Maintenance / Service | 19 | 05-25-2012 04:36 PM |
| Anyone find out how to turn off the seatbelt chime? | overboost | General Yaris / Vitz Discussion | 54 | 11-22-2008 10:07 AM |
| what water temp does cooling fan turn on | gonzo452001 | General Yaris / Vitz Discussion | 10 | 11-07-2006 05:50 AM |
