Old 05-15-2009, 12:15 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by philwept_33 View Post
Hi im new on this forum so hoping someone out there can help me out.
On Christmas day the engine let go, so to cut a long story short got another one and although its from a 2003 and a 1sz engine code its an earlier one as the PAS pump is on the front of the engine rather than electric one which the car already has.
I fitted most of it yesterday however some of the sensors are not fitting. The main concern its the cam shaft position sensor as its is a 3 pin. On removing the old 2 pin one it seems about 5 mm longer meaning it fouls the cam shaft.
Please can someone help me on this as its been going on for ages and getting expensive!!!
thanks in advance - phil
you'll need an ECU and wiring harness to go with the new engine.
Toyota Yaris Engine Map wariss Performance Modifications 5 03-15-2009 12:21 PM
engine swap complete! Adriaan Canada 3 03-05-2009 10:50 PM
