Old 05-20-2009, 09:35 PM   #1
bieniman
bieniman's Avatar
Drives: vitz rs 1500 2001
Guys,
I've been following this mod for a while now,
If I'm correct the newer yaris models have electronically controlled TB. Well, I looked under my hood and see sort of like a cable running from the pedal to the TB, I can rev my engine by turning this swivel.
bieniman is offline   Reply With Quote
Old 05-20-2009, 10:12 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by bieniman View Post
Guys,
Yes, this mod only applies to the Drive by wire system that is in the ( i believe) '05 and newer
Old 05-20-2009, 10:33 PM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Guys,
I'm not 100% positive on this but the scion xa/xb owners have done a swap with an older 1zz throttle body which is drive by cable like yours. check the forums @ scionlife.com you should be able to dig up more info.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
