![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Need HID Help!
I'm a total n00b when it comes to all things HID so forgive my ignorance. I'm looking to purchase one of the kits from Xenon-Vision, but I have a few questions before I dive in.
1. What's the difference between the xenon & bi-xenon kits in terms of quality and install procedure? 2. Will I lose my high beam indicator with either kit? 3. Do I need the flicker relay or battery relay that can be purchased with the hi/low ($120) or fog light kit? 4. Will I lose my fog lights with either kit? 5. Do I need to disable DRL? 6. Is there any difference in the way these operate from the OEM? Or just turn the headlight switch and you have brighter lights? Any help/advice would be appreciated |
#2 | |
#3 | |
#4 | |
I asked him about that too and was told it is not necessary on the Yaris since there is no known issue with flickering. I guess whoever's having a flickering problem either has it wired wrong or maybe it's just a fluke. I figure I'll install it without the 'anti-flicker harness' at first, since I can always just purchase and install it later if I have a flickering problem.
Agreed in those regards but I'd rather do it once and not have mess around with it once set up.
I hear ya... just not sure it's worth the extra $30 if it's not something we really need.
Just received this message from Phu: "The fog light will work fine with the bi-xenon kit. The bi-xenon kit doesn't disable the DRL, it just that the DRL doesn't turn on with the bi-xenon kit."
I think that I might jump for the bi-xenons. I will be very disappointed if I install them and need an anti-flicker harness though.
I'm going for the bi-xenons as well... and ditto on the harness. Although, if you look at the website, it doesn't show the 'anti-flicker harness' as an add-on for the bi-xenon kit. The page for the regular HID conversion shows the anti-flicker harness, battery relay harness, & slim ballast as 'upgrades' while the bi-xenon kit only lists the slim ballast as an 'upgrade'.
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
