Old 05-05-2010, 04:43 AM   #1
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Looking good! It looks like your passenger side is tucked in a few mm more than the driver side though.. my Yaris is the same..
Old 05-05-2010, 09:35 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thanks
What do you mean? where did you see that?
D.
CLA 250, 4MATIC
Old 05-05-2010, 08:52 AM   #3
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
I just installed these on my car and they look amazing! I'll take pics when the car is back on the lift. Just remember to be careful while doint the install, you don't want to screw the threads up like me It's also best to have someone else there to help you out too.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-06-2010, 12:14 AM   #4
derickveliz2
I just put my new wheels and I have rubbing issues in the back, I tried to uninstall the spacer but it was impossible. )o: any tips would be appreciated.
Thanks.
CLA 250, 4MATIC
Old 05-11-2010, 10:17 AM   #5
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Thanks.
Photobucket images are blocked at work, so I can't see the pic. Anyway, will some kind of "puller" work? (Someone else mentioned a steering wheel puller, but I believe that was used to remove the brake drum.) Along with some heat and PB Blaster? I'm sure that bit of rust is holding it on... Even if you can't work on it today, getting some PB Blaster sprayed in there now would give it a couple of days or more to work it's magic. Then you can try again on the weekend.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 05-11-2010, 11:00 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Might be a stupid question, but if someone installs the Rear Disc Brake Conversion Kit the spacers would be a moot point correct?
Old 05-17-2010, 02:28 PM   #7
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
they wouldn't be moot but you would need another spacer for the caliper.
I know a guy out in Europe installed a set of the PG spacers on his Vitz RS which had rear disc brakes. :)
Russelt3hPirate is offline   Reply With Quote
Old 05-17-2010, 12:24 PM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im curious if someone tried adding washer on the bottom..to make the tire tilt by a little angle..
Old 05-17-2010, 02:27 PM   #9
Russelt3hPirate
l33t3st Asshole
The Penguin Garage Camber Shims did exactly that. :)
Old 05-17-2010, 02:32 PM   #10
marcus
toyota
marcus's Avatar
kewl..im assuming it comes with it.... is the stickers still free by the way..anyone..thanks..
Old 05-19-2010, 07:04 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
i have spacers that i've manufactured for another car. for disc brakes. i won't provide bolts though.
Old 06-05-2010, 02:08 PM   #12
marcus
toyota
marcus's Avatar
I'm curious what the 10mm Allen key is used for?
Old 06-05-2010, 02:28 PM   #13
marcus
toyota
marcus's Avatar
Forget it I found it
Old 06-13-2010, 03:55 PM   #14
marcus
toyota
marcus's Avatar
just to add on to this..for hatchback left rear is about 4mm pushed in vs the right.. i did an install on pg spacer left rear 13mm and right is 10mm and i got it pretty close to match..yaris frame is crooked by about 4mm rear left.
Old 06-21-2010, 02:41 PM   #15
marcus
toyota
marcus's Avatar
this thing wont work for 205/50/16 +40 offset. i did 13mm on left and 10mm on the right (due to left goes in more than the right..)got it flush on both side but still rubbing on the right shaved the fender worked well but with soneone on the back still getting rubadubdub on dips..i should have placed the shim .damn it! but now i dont want to do it if its not gonna fix the issue..1degree ?? would that move the upper tires in by what 2mm or less..
update... left rear for hatch is 5mm off vs right rear.. get 13mm n 8mm or 15mm n 10mm
Old 08-02-2010, 11:14 AM   #16
derickveliz2
I installed a camber kit, thanks to Garm and other yariswold members for your suggestions trying to avoid rubbing.
The installation is very easy if you have done the spacers, I added -1.5 degrees and Looks and Feels AWESOME!!! it does help with the rubbing issue but I still need to drive with more weight and find out.
D.
Old 08-03-2010, 07:53 AM   #17
33OH
Drives: '08 Yaris
My right side is out further than the left, actually.
Old 08-03-2010, 09:00 AM   #18
derickveliz2
I know what you feel, you are not alone...
It bothers me a little bit, but If I don't tell.. nobody notice the discrepancy.
D.
CLA 250, 4MATIC
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
