Old 05-23-2009, 02:44 AM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by MGargano View Post
So I should turn it all the way in, then back out 1.5 turns? If not, what's the 'correct' procedure for adjusting the idle screw?
  1. Turn engine off
  2. Adjust the screw to your liking
  3. Turn engine on and test for oscillation and high idle
  4. If you need to modify the value, go to step 1
  5. If you're satisfied with the setting, throw some epoxy in there and let dry (optional, but recommended)
FYI, I've read that it's better not to try adjusting the screw with the engine on, or else the ECU might need to be rebooted one last time to reset the values.
I had no idea which direction to turn to or anything like that... All I did was turn clockwise until I found the best setting after the second try. I guess I got lucky, because the damn screw got stripped at a very decent setting, so I didn't need to do any tweaking afterwards.
I also let the gasket maker do its thing for at least 4 hours IIRC, with the battery disconnected the whole time. I also did the coolant bypass, but didn't need to burp it afterwards.
No big oscillations, no CELs, and a pretty decent 2.5K idle... could've been a bit better, but I'm not complaining.
Old 05-23-2009, 11:22 AM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I am gonna watch it over the week or so. My cold idle is 1.5k. and i didnt touch the screw. If it comes back the i will look into it but for right now its running great. I had to install the orignal TB back on to get the drill to drill out the rivets and forgot to reset the ecu when i replaced it with the 1zz. Then i drove it a bit not too hard. Then turned it off for 5 min or so. when i started it up again oscillation gone. Drove it again. Turned it off. Started up cel gone
Think my ECU went to college
Old 05-23-2009, 11:28 AM   #3
Yoda
Yoda's Avatar
  1. Turn engine off
I thought you were suppose to do it while the engine is on. Look at it like a clock and turn buy 2 each time as you find the sweet spot(form 12 oclock to 2 or from 12 to 10 and so on) At each turn let the engine settle at the new position for 3 min if not the right idle turn it again. Not sure if its the same for our car tho.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
