Old 05-25-2009, 06:40 PM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
New Scangauge owner questions
I tried searching the forum already, but I haven't found any answers. I apologize if I missed them. So far the only configuration I've done on the SGII is change the engine size to 1.5L.
1.) The TPS readout never seems to go below 14, and at wide open throttle reads 80. Is this normal?
2.) Shouldn't the iMPG register 9999 (DFCO) a second after I take my foot off the gas entirely? It only seems to do it when I'm driving around town. On the highway it jumps into the 140mpg range when I take my foot off the gas.
Thanks MPGers!
Old 05-25-2009, 08:47 PM   #2
supmet
Drives: 2007 4 Door Yaris
2) DFCO requires the engine to be at a certain RPM to activate, so just taking your foot off the gas doesn't guarantee DFCO.
Old 05-25-2009, 08:50 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Ahh, I see. Thank you!
Anyone have answer for #1?
Old 05-25-2009, 09:04 PM   #4
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I believe the throttle body is limited to around 80% open for WOT on the yaris. One benefit of upgrading to the Matrix/Corolla throttle body is that it is a larger opening to begin with so 80% is actually allowing more air than the stock TB.
Wanted: Forced Induction
Old 05-25-2009, 09:18 PM   #5
PreciousPups4U
I really LOVE this car!!!
PreciousPups4U's Avatar
Drives: 08 Bayou Blue LB AT
When I set up my scangauge I seem to recall having to set engine size to 1.5, gas tank size to 11.1 and TPS to 21 (this might fix your problem). I seem to recall reading the TPS setting thing on here somewhere, maybe from Bailout.
Someone please post if I have the numbers wrong or if there is something else that needs to be set up initially.
Cindy
Old 05-26-2009, 05:33 PM   #6
BLH
Drives: 2007 Yaris Sedan
#1. Mine says 14 or 15 with no pressure on the accelerator.
BLH is offline   Reply With Quote
Old 05-26-2009, 05:38 PM   #7
schleppy
I love momentum.
schleppy's Avatar
Where do you set the TPS?
Old 05-26-2009, 06:28 PM   #8
PreciousPups4U
It is in the setup somewhere. It's been so long I don't remember, but it is in the instructions.
Cindy
Old 05-27-2009, 09:18 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
To me 15-80 seems to be the TPS range... sometimes it'll go to 14, 13 is the lowest i've ever seen, but generally 15-17 is what I see.
DFCO doesn't appear for a prolly 1-1.5 seconds after I take foot off pedal for me... seems to be a lag in the SG. ALso... DFCO kicks in much quicker when the engine is warm... I've noticed it doesn't like to go into DFCO when the engine is say... 90F or lower.
Old 05-28-2009, 05:45 PM   #10
BLH
Page 16 of my manual.
MORE>SETUP>FUEL>CUTOFF
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 01:18 PM
Performance Noob Questions fatjerkgary Performance Modifications 20 05-11-2007 11:20 AM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 11:36 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 02:42 PM
new owner.. have questions chibianh General Yaris / Vitz Discussion 8 05-14-2006 12:44 PM
