Old 05-28-2009, 09:43 AM   #1
RocknRollRon
Drives: '07 Yaris LB, White (The Egg)
56k and the main computer went - has this happened to you?
My Yaris died and needs a new computer. Dealer tells me the warranty goes to 60k and I just made it...only have about 56k. The new computer will only have a one year (unlimited mileage) warranty.
mine is a 2007, Hatchback.
I heard that the computers are a problem in the Corolla and the yaris....
Anyone else have this issue?
RocknRollRon
Somewhere in New Jersey or beyond
RocknRollRon is offline   Reply With Quote
Old 05-28-2009, 09:46 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
what modifications have you done to your yaris? sound system?
Old 05-28-2009, 09:54 AM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
What happened when your computer "went"?
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 05-28-2009, 10:01 AM   #4
RocknRollRon
Really there's been no modifications other than some fog lights more than a year ago....the car just cut-out, the engine light went on, and it keep rolling with no power....didn't stall, engine sounded fine - just wouldn't move much...restarting didn't help...AAA towed it to the dealer...they pushed it in....part is on Back Order...got a free 2009 matrix to zip around town in...
RocknRollRon
Old 05-28-2009, 10:44 AM   #5
auxmike
auxmike's Avatar
That's awful!
Please let us know how it turns out and how long the wait was for the computer.....
Old 05-28-2009, 10:56 AM   #6
never had a cpu problem with my matrix....but the ecu for the matrix/corolla isnt in the engine bay
Old 05-28-2009, 10:57 AM   #7
2009Toyotoad
Drives: 2009 Yaris 3dr
The same thing happen to me on my 1992 Civic. However in this case I know the issue was related to bad mechanic service. ECU failure was right after the coil was changed out. Anyone guess as to why the coil change out cause the ECU to fail?
Simple because the D###A$$ didn't disconnect the battery and left key on while changing out the ignition coil. I hope that SOB limped for a month afterwords. The 50 AMP ignition fuse also failed a few day later.
2009Toyotoad is offline   Reply With Quote
Old 05-28-2009, 11:41 AM   #8
RocknRollRon
OK- let's focus here....has anyone else had THIS problem with their YARIS?
RocknRollRon
Old 05-28-2009, 07:15 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
It could be just a lemon, nothing to worry about.. like REALLY...
Now, it could be really WRONG when the garage sees your new ECU and says "ah ha!! you've got yours changed too!" as i heard about my dad's 91 plymouth voyageur... but i think this is very likely to happen. See never going to happen. hehe
Old 05-28-2009, 08:31 PM   #10
RocknRollRon
new ECM module installed
Wow! Yesterday it was on backorder & would take a few days - today I get a call @ 2:30 and the job is done. Apparently, they were able to locate the part and have it overnighted!
Swapped the free rental Matrix this evening and the Yaris is better than new...nice shiny ECM under the hood...runs great-no complaints....
Supposely I have a one-year, unlimited miles warranty on the replacement part.
Anyone else have an issue like this? I can't believe I was the only one...
RocknRollRon
Old 05-28-2009, 10:31 PM   #11
Did they keep the bad ECU? It would be very interesting to see what failed.
Mitsubishi had an issue a few years back with bad capacitors. I repaired a friend's Mazda pickup's ECM that had the cap issue (Mitsu made the ECM for Mazda).
Old 05-29-2009, 08:38 AM   #12
Originally Posted by voodoo22 View Post
Are you able to confirm it's a new ECU or you're going on their word?
toyota dealers usually have to submit the broken parts back to toyota canada to get paid for them, so chances are good they just swapped the ecu...quick and easy
Old 06-23-2009, 03:59 PM   #13
RocknRollRon
Still goin'
Update:
Confirmed: ECM is new...no problems other than the dopey dealer disconnected the air cleaner and didn't put it back together.
1200 miles on new ECM. knock on wood...aproaching the 60k mark fast...
Cheers
RocknRollRon
