![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
1ZZ throttle - Not Optimized Yet!
Well, just finished the 1ZZ install without a hitch. No cel! The problem I saw when I installed the throttle body was the manifold has a opening which is too small and restricts the airflow. To really take advantage of the new throttle body, I think we need a newly designed intake manifold. Any thoughts??
In addition, what intake system are people using with the new throttle body? Perhaps something designed for the 1.8 liter TS or even a Matrix intake? |
toyota
yah someone had a prototype but i guess decided to cancel the project..*sigh* too bad.. 15-20 hp increase for under $700 sounds very reasonable.
^yeah, but garm is picking it back up
![]() To the OP, if you feel comfortable, you can port match the intake manifold, it just wont fit the stock TB with its gasket after you do this |
It's picked up. DynaTek is interested, and I already have a backup fabricator if they fail to come through again. However, the intake manifold project was based on using a stock throttle body. If we limit it to throttle body swaps, it might mean not enough sales to do the manifolds. And I'm not doing a bunch of versions, so let that be known.
As long as the new intake manifold is made out of metal and it is thick enough, it can be bored out. This will avoid the strange 90 degree lip where the throttle body connects to the intake manifold. Even more gains!
As long as there is a will, we will find a way! |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
i haven't looked at the manifold entrance but can't the plastic one be bored out?
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
I'm pretty sure the plastic one can be bored out. Use a dremel tool or something. I was actually thinking of doing this soon but i messed up my manifold so i'm looking for a stock manifold to buy. hahaha
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
#9 | |
Frown, I'm not saying I won't do it, but it will be dependent on interest, how many people want to go the whole way with intake mani + larger TB.
I would be interested, already planning on swapping the throttle body as my next project. I don't know how much something like an intake manifold costs, but it sounds useful.
I've swapped mine, Garm, but I'll go with whatever you produce and mod it if necessary.
Thanks for picking the ball back up on this. I think it will make significant gains.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
The butt dyno IS subjective, that is true. But when someone like Jkuchta, whose racing and technical expertise surpasses my own, says it makes a difference, I'll take that as being true.
I used to have 1700 posts
Hey Garm, when can we expect to see the production pieces done assuming DynaTek does pick up the production for the intake? I'm not sure you mentioned this in the intake thread. I'll take whatever you make!!
I'm not sure, but I'm having a phone conversation with DynaTek again tomorrow.
An improved intake WITH the 1zz throttle body is going to make some awesome gains! I CANT WAIT!
37HSSV
Garm, why dont you make the intake manifold bolt up for the 1zz TB, then sell it included with the kit, core pricing and all till the buyer sends back the old one. Or you could offer a simple adapter plate for those who wish to stick with the stock TB.
This way so the peeps that decide to go with the larger TB arent needing to bore out their new Intake manifold, and a simple bolt on plate would allow stock TB users the same use of the product. If Morgan can use that "boating plastic material" (forgot the name) to make an adaptor plate for the TB from the Xb to Yaris, what says we couldnt do a choker plate for the stock TB?
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
| 1ZZ Throttle Body Spacer | tk-421 | Performance Modifications | 34 | 07-11-2017 09:48 PM |
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
