Old 06-09-2009, 05:37 PM   #1
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Its a first.
The Spectacle is offline   Reply With Quote
Old 06-09-2009, 05:49 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
Originally Posted by The Spectacle View Post
Its a first.
now like a 2nd or 3rd...
mikenacarato is offline   Reply With Quote
Old 06-09-2009, 05:56 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
bench racing = real-life, knuckle-skinning experience, didn't y'all know? that's why we can "slap on" turbos and coilovers....
Old 06-09-2009, 10:09 PM   #4
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
lol @ the bashing on spectacle.
Old 06-09-2009, 11:07 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
you feel left out?
Old 06-10-2009, 02:05 AM   #6
CDavis7M
Drives: 1990 Supra Turbo
I don't have any experience with a Yaris, let alone a turbo one. But, I do have a turbo supra.
Here are some of the basics that I know about Turbo cars. Please let me know if I am wrong though.
-A car with a Turbo stock will have an ECU that is set to retard timing at higher rpm / higher boost.
-Turbo cars have much lower engine compression and are better able to handle boost.
-NA cars try to achieve a Air/Fuel Ratio of about 14.7, probably richer than that at about 13-14 or less when at full throttle.
-A Turbo cars ECU is set to run at 11-12 AFR at full throttle. Running richer allows the gas to cool the piston and reduces the risk of detonation.
-Turbo cars usually have some or all of the rotating assembly forged.
So, basically, running a turbo without any modifications on an economy engine, you will detonate with AFRs around 14, even at 7psi. I hope someone before me set you guys straight but this thread looks like Honda Tech. It's just horrible.
CDavis7M is offline   Reply With Quote
Old 06-10-2009, 02:15 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
guessing you missed the part where we suggested bigger injectors to help with the "stock" AFR's ?
when the car goes into open loop mode, larger injectors will provide more than enough fuel to keep boost mode cool
Old 06-10-2009, 04:01 PM   #8
CDavis7M
This will work. But, obviously it's not the best idea. And considering the cost of a piggyback and a tune compared to the cost of a turbo, I don't see any reason to risk an engine to save a few bucks.
You've clearly missed quite a bit of this discussion, you haven't played with a 1.5L Toyota motor, and your tone of disrespect (post count: 4) for some pretty knowledgable tuners is the horrible part. /rant off
I did miss some of the discussion. And sorry for the disrespect. But, calling out someone based on post count is also immature. I would expect better from a vendor.
Originally Posted by mikenacarato View Post
a yaris motor is quite different than a turbo supra motor..correct me if im wrong though please.
That's what I was suggesting.
Old 06-10-2009, 10:39 AM   #9
I hope someone before me set you guys straight...It's just horrible.
Old 06-10-2009, 02:56 PM   #10
Split
Drives: 2008 Yaris Sedan
someone put one of these turbos on the yaris:
http://www.compturbo.com/products/in...&product=CT340
TO4E T3/T4 Hybrid turbocharger with a 40mm Comp wheel stage 1 turbine wheel .36 Non-Port T3 turbine housing.
The Triple Ball Bearing version is only $1600. Instant 250hp at low rpm would be nice!
Split is offline   Reply With Quote
Old 06-10-2009, 03:00 PM   #11
mikenacarato
SIPNDEW
Drives: 15 STI
i think people forget that all cars are NOT the same.....a yaris motor is quite different than a turbo supra motor..correct me if im wrong though please.
Old 06-10-2009, 05:05 PM   #12
mikenacarato
SIPNDEW
Drives: 15 STI
just curious.....do you have a yaris cdavis? if not...why are you here?
Old 06-10-2009, 05:35 PM   #13
CDavis7M
yes
Old 06-10-2009, 05:40 PM   #14
mikenacarato
SIPNDEW
Drives: 15 STI
well welcome aboard.
Old 06-10-2009, 05:45 PM   #15
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
research is golden, if you were trying to bash him, ye lose all chance now... sorry mike lol
Old 06-10-2009, 05:52 PM   #16
mikenacarato
SIPNDEW
Drives: 15 STI
oooh man...im gonna lose sleep over this one...
Old 06-10-2009, 05:51 PM   #17
Another problematic approach (so far) -- piggyback didn't work for me and several others. Doesn't mean it can't work, but you posted this (I'm guessing) without real world knowledge of a successful application on a Yaris. Another indication you are drawing from other-car experience, not specific to the Yaris, and also an indication you haven't read the other threads about tuning these cars. Not totally irrelevant, but not all that helpful either.
Sorry about the post count snipe, but you pissed me off. I found my happy space again since then.
Old 06-10-2009, 07:21 PM   #18
CDavis7M
You are right. I'll do more research before I make Yaris specific advice.
Small cars stacked up at dealerships. freeridelectric New YARIS Purchase Forum 11 04-24-2009 08:23 AM
Small car's name? yaris-me Off-topic / Other Cars / Everything else Discussions 13 03-29-2009 02:43 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
How Small Would You Go? Nigal General Yaris / Vitz Discussion 26 06-15-2007 08:44 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
