Old 06-09-2009, 12:26 PM   #3
Morgan
Morgan's Avatar
Drives: 07 MM LB
... you'll have to drop your front subframe to get the bar in/out. not a 1 person job.
+1, after removing my subframe and installing it twice, at the minimum removing the back 4 bolts and letting the subframe hang from the front 2 bolts, even then its still a pain - the front is not as easy as the 5 min installation of the rear sway bar
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 08:07 AM
Sway bar opinions Nelson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 12-10-2008 06:40 PM
