Old 06-10-2009, 12:39 PM   #19
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
went from 108 hp and 103 tq to 111 hp and 106tq with just the TB upgrade isn't too shabby for just bolt-ons.
Old 06-10-2009, 12:43 PM   #20
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
great power comes with great responsive tb..oscillations lolz.
Old 06-10-2009, 12:58 PM   #21
no oscillations if modified and installed correctly.
Old 06-10-2009, 01:07 PM   #22
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
This^
Old 06-10-2009, 01:10 PM   #23
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Was the intake manifold port matched?
Old 06-10-2009, 01:24 PM   #24
ROCKLAND TOYOTA
TRIM HUNTER
im gonna say no unless there's a DIY somewhere i haven't seen .
Old 06-10-2009, 01:30 PM   #25
Yoda
Yoda's Avatar
no but i was thinking that. Its just plastic is it not?
but anyway look wat i found today
http://www.importfaceoff.net/race_rules.htm#TESTANDTUNE
And here i thought there was nothing for imports in gainesville
Nascar races and drag strip is all we got. We get PINKS coming out here pretty offten tho.
Old 06-10-2009, 01:43 PM   #26
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Not too bad. Every little bit helps I suppose.
Old 06-10-2009, 04:45 PM   #27
Yoda
Yoda's Avatar
i will see if i can squeeze 120 out of it
Old 06-10-2009, 04:52 PM   #28
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
im looking for that intake porting DIY. i have a spare one lying around i'll use a a test mule.....
Old 06-10-2009, 04:55 PM   #29
Yoda
Yoda's Avatar
o yes sweet. how much for an extra IM?
Old 06-10-2009, 05:57 PM   #30
kngrsll
Apexing Egg!!
kngrsll's Avatar
i dyno'd 87 hp stock... id love to see 111! lol
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-10-2009, 06:10 PM   #31
Thirty-Nine
I port-matched the intake manifold on my old 2001 Ford Focus, which also had a plastic manifold, to a larger aftermarket TB. Easy to do; just don't remove to much material. I plugged the IM with rag, ran a vacuum cleaner to suck out the shavings, and used a Dremel tool. It helps to have a second person holding the vacuum, obviously! Also, with a plastic IM anda a Dremel, don't run the tool at too high of a speed for melting reasons.
I can't imagine it'd be much more different on a Toyota ...
Old 06-10-2009, 08:51 PM   #32
merryandlovely
Drives: Toyota
That graph shows a lot more than 3 WHP increase. You sure you you are reading it right
merryandlovely is offline   Reply With Quote
Old 06-10-2009, 10:09 PM   #33
ROCKLAND TOYOTA
TRIM HUNTER
its 3 when you see the last dyno is WITH the new TB installed.....
Old 06-10-2009, 10:13 PM   #34
Tamago
Tamago's Avatar
Drives: UZJ100
those curves aren't before and after lol.. you sure YOU're reading it right?
Old 06-10-2009, 10:26 PM   #35
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
im stunned that an exhaust does so much on this car
i put down 104 hp 104 tq with the TB, k&n intake, and underdrive pulleys. he has done a header and exhaust and made 7 more hp. sweet :)
Old 06-10-2009, 10:46 PM   #36
ROCKLAND TOYOTA
TRIM HUNTER
his muffler is TRD which in hoping is the jdm one like mine.
My DynaPack Dyno Results. PETERPOOP Performance Modifications 63 03-10-2009 06:02 AM
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 05:28 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 05:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
